Holmes Products HCH4062 Ceramic Compact Heater
Problem for Holmes Products HCH4062 Ceramic Compact Heater
My heater will kick on right away but after
By jessica_h816 on Oct 19, 2009
My heater will kick on right away but after 3-5mins it stops producing heat then a few mins later it will start heating again. Why?
Solution #1
posted on Oct 26, 2009
Not Rated)
billyvangogh
Rank: Guru  Air Conditioners  Expert
Rating: 88%, 32 votes
The furnace could be shutting off on High Limit ...means your furnace is running too hot...check your filter and make sure return air vents are clean and clear....also it can be the Heat anticipator in your thermostat...which controls how many times your furnace cycles...basically your furnace should come on and off 5-6 times/hr ....need more info on your type of furnace and type of thermostat
Was this helpful?
Yes
No
Popular Solutions for Holmes Products HCH4062
Questions and Unsolved Problems for Holmes Products HCH4062
Do you recommend Holmes Products HCH4062 Ceramic Compact Heater?
Answer
Answer
Hi!I have Model #6901050100, Cat.#DS3311 volts 120,watts 1500 air heater.The faux fire works just... (More)
Answer
My heat pump was built in Osgood ON. CA. by the Canada Heat Pump Co. I do not have a manual for it... (More)
Answer
The heat pump starts runs 2 min. stops restarts 7 min. later. When it stops after the short run it... (More)
Answer
have dayton 150,000btu heater won't ignite right off have to try it 5 or 6 times to light once it... (More)
Answer
burner not igniting. i followed the instructions behind access panel to restart the heater, but... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
in , FL
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
