Question about Panasonic PT-51HX41 51" Rear Projection Television
Power cuts out
My tv will power up and cut off in two to three seconds. I have tried different outlets to no help.
  • Panasonic Master
  • 5,138 Answers
This one would be hard to say what maybe causing it to shut down there is alot of different reasons why one will come on then shut down -poor connections ,cold solder joints ,leaky or bad capacitor you guess which one? Bad flyback transfomer! ect..ect,,,,ect call a repair shop.
Posted on Jan 27, 2008
My Panasonic tv cuts on and cuts back off it will not stay on for me to try to reset it
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Aug 18, 2013 | Televison & Video
Element 3711b screen is black with no sound
Try unplugging your receiver from the electrical outlet for 10 seconds to have the receiver reboot. You can also check your connections from the TV to the receiver to make sure they are secure. The last thing to try is a different cable from the receiver to the TV. Thanks.
Dec 25, 2011 | Element Electronics Televison & Video
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
Machine not turning on
1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Hope i could help you.
Have a nice day : )
Sep 04, 2011 | Microwave Ovens
Microwave has no power when plunged in
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Apr 04, 2011 | Maytag Microwave Ovens
Had it three weeks was working fine until the next cut and it would not power up not a sound of anything
Assuming, you did try the unit in a totally different outlet location, there may be problems with the trigger switch. Call the Kawasaki customer service for the nearest service center 1800-590-3723
Dec 04, 2010 | kawasaki 840068 Green 5 Amp Reciprocating...
Elitegroup P4M800 motherboard problem get power for 1 sec thats it real puzzle!!
You ask for two problems here, but let's talk one by one.
According to your explanation it seems to be bad wall outlet connector, broken power cable and finally a broken Power supply.
You can check first two, but to you can't check Power supply.
The point the status led is off means that the 5V part of the power supply is broken. 12V part is (probably) OK because you have a fan running for short, but it is not important because all power sources of the power supply should work.
Now, the best for you is first to (try) buy a new strong power supply (you said you have more devices in your PC) and try with another power cable connected to another wall outlet.
First you should see if you get a status led ON. If so, than your PC should work.
Second question:
three beeps suggest bad memory (it depends of the BIOS). If you have more then one module, try with one only and then with oders, but only one at time.
Regards.
Mar 27, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
Cuts off after 2 seconds
Just a hunch; plug it in to a different outlet.
AC outlets are only marginal when new and that unit can draw well over 10 amps.
If the contacts are failing, the unit will think it has been disconnected, killing off the clock setting too.
If that doesn't help, try plugging another high power appliance, an iron, toaster or coffee maker, into the same outlet used for the GE to see if they behave normally.
Jul 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Model # WF20L6 symphonic
This particular model has a history of this problem.
This sounds like a safety feature built into the television. It may be trying to protect itself from an unsafe electrical source. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly.
May 28, 2008 | Televison & Video
Panasonic PT-51HX41 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
