-   it same here the light goes on one second then the machine shut-off and unable to turn it on again...everytime only can stay for 1 or 2 mins max.....what's wrong with this heater,it is not really heating....-   rachel w
Jan 27, 2008
-   i have the same problem, the light blinks once when i press the power button, but that's it, it won't come on; can't find the manual and honeywell's website says it's not available; any ideas?-   combs_cl
I have the HZ-7000 (one without the remote), and it did the same thing. If you unplug it and wait a bit, the overheat sensor should reset. If nothing else is wrong with the heater, you should be able to plug it back in and it will run again.
it runs for only ten minutes tops and just stops? then i it just wont turn back on at all? I unplug...
(More)
it runs for only ten minutes tops and just stops? then i it just wont turn back on at all? I unplug it then try to plug it back in and it wont turn on ? I cannot seem to figure out how to adjust the heater settings either? I just happen to find this heater and clean it up so i do not have a manual...
The Honeywell thermostat 32207502-002 does not work in heating mode in the mornings. Hoewver, it...
(More)
The Honeywell thermostat 32207502-002 does not work in heating mode in the mornings. Hoewver, it starts to operate after 12pm approximately. Does the thermostat need to be replaced or could the problem be somewhere else? A technician came overe and he replaced a wiring harness in the hearing controls of the furnace. When he came was close to noon and he got it to work, and said the thermostat is OK. But, later at night the thermostat quit working maybe after midnight. Your opinion will be appreciated. Regards, Jose
