Barbara Ferraro I would like to tell yoy yhat Jasco Appliance was recomended to fix a problem we had with our washer walking on high speed after having it for seven months. The service man was useless I would not pay the bill they send you or recomend them any more. he just stood and looked at it and said go and buy some rubber stoppers and have a Grandchild crawl behind and place it under the feet. I see no reason for you to pay him for this visit. Barbara FERRARO 95 West Squae Drive Richmond VA. 23238 804 784-5377
Did you remove the shipping bolt when you in stalled it consult your owners manuel under installation if not removed will hop like a rabbit-tech17
Posted on Dec 29, 2007
Speedometer doesn't work every time the instrument cluster light is on. I tried covering up the sensor with no avail
Its a connection problem. Also the sensor system in you blazer could be worn out. Too expensive to fix. Get a Garmen GPS. It tells you your current speed and all that other good stuff. Highly recomend.
Oct 09, 2014 | 2001 Chevrolet Blazer
Speedometer not working
Hi Anonymous, before I spent any money I would check fuses, then try and retrieve any trouble codes that may have been generated. I don't know if the speed sensor works the same way as the one in big twins do, but removing and cleaning the end of it can't hurt and it only takes a minute and it's a recomended procedure fix for the big bikes. Here are a couple of sites that can walk you through it: http://www.fuelmotousa.com/p-29661-harley-trouble-codes.htmlt
http://www.ehow.com/how_12192050_replace-speed-sensor-harley-sportster.html Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 12, 2014 | Harley Davidson XL Sportster 883...
The water is not spinning out. the water is pouring out onto the floor when the spin cycle starts. not leaking when in wash cycle
You may have a pump that's bad. When it goes into spin cycle it assumes the water will be drained within a period of time before it goes into high speed spin. If it goes into high speed spin and the pump hasn't done it's job then you will get a bad mess, flood, water all over.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Kenmore 9380x Top Load Stacked Washer /...
HOW TO FIX A BLOWN HEAD GASKET ON A 1997 PONTIAC
This is a very lengtht process so my suggestion to yoy is to go to an auto parts store and ask for a "chilton book" for your vehicle.this book will walk you through the process
Apr 16, 2010 | 1997 Pontiac Trans Sport
Maytag Neptune front load washer, model MAH8700AWW, 4-5 years old. At ant low or high speed spin cycle, the drum bangs badly regardless of load size. Why & what can be done to fix this?
Your bearing are broken or wearing out.
Replace the bearings.
This requires taking the whole machine apart and requires special tools.
I would call a appliance repair company in your area.
It can be very expensive to fix.
Maytag machines are not my favorite.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
Will only spin slow speed will not spin at high speed. Everything else seems to be working fine.
Make certain that your selected wash cycle designates a higher spin speed. If so, then you may have an issue with the motor or motor control board. Contact an appliance service company.
Feb 22, 2010 | EuroTech EWF172 Front Load Washer
Kenmore washer-top loader-replacing water pump
Had to pry it off. It took about 45 minutes to get it to come off. The reason it was so hard to get it off was that the shaft of the motor was pitted and rusted some. The new pump then wouldn't easily slide onto the shaft, so we had to use a file and sandpaper to make the shaft smooth. We then used WD-40 on the shaft and it went on rather easily, but was still plenty snug. We put the clips back on, the hoses back on and bingo, we fixed it and saved about $150.00. Neither myself or my husband had ever attempted to fix a washer or any large appliance before. Times are hard and we decided to try it on our own and were happy we did. No more leaking at all. It was a "high five" moment!!! Barbara Giles
Feb 02, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer Model #16852 make high pitch sound while spinning.
Is the high pitched sound that you hear during the spin cycle or just all the time during the wash? If it's during the spin cycle it's probably your transmission and the only way to fix it is to replace the transmission. It's only going to get worse with time and soon enough it will just seize up on you and nothing will work. A transmission for a Kenmore runs anywhere between 150 to 250 dollars. 150 if you can find a refurbished one. You can find them at any appliance repair shop. Kenmore transmissions are fairly common as it's a big name. I hope this helps you and if you have any other questions or need help with installing it let me know. I can give you an easy step by step walk through on how to install it. It doesn't take too long. Good luck to you.
Jan 05, 2009 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
250 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
