Question about Microwave Ovens
Maytag Over the oven microwave
I have model # MMV5000ADA ,13.5 amps, watts 1450, vac 120, HZ 60, DHHS code No. H7NF Manfactured in Cleveland, OH in April 1998.
My problem started when I was defrosting some fish. I turned on the light under the hood at the same time and I got a bright flash from the light unit and the microwave stopped working. I believed that both lights had blown. Since then, I have attempted to replace the lights { I get no response}. When I start the microwave, I get a humming sound and the food does get hot, but it is not evenly heated. Also, the vent fan is not working. No circuit breakers were tripped and all other operations on the microwave keyboard continue to function except the light switch. I have unplugged the microwave for several days and then attempted to operate the microwave with the same results. I have defrosted meat before and turned on the lights simultaneously, but I this never happened before.
Posted by Watsonism on Dec 29, 2007 Report abuse
My problem started when I was defrosting some fish. I turned on the light under the hood at the same time and I got a bright flash from the light unit and the microwave stopped working. I believed that both lights had blown. Since then, I have attempted to replace the lights { I get no response}. When I start the microwave, I get a humming sound and the food does get hot, but it is not evenly heated. Also, the vent fan is not working. No circuit breakers were tripped and all other operations on the microwave keyboard continue to function except the light switch. I have unplugged the microwave for several days and then attempted to operate the microwave with the same results. I have defrosted meat before and turned on the lights simultaneously, but I this never happened before. The turntable is not working, but the vent fan settings [high & low] both work when I turn them on manually.
Posted on Dec 31, 2007
Is the turntable working
Posted on Dec 29, 2007
Sharp microwave sparks in ceiling of microwave when turned on
At 14 years of age, it probably is due for replacement.
Jun 10, 2017 | Sharp Microwave Ovens
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
What is the wattage on the sharp microwave model r-2a48?
http://www.sharpusa.com doesn't have your manual. But you can find it yourself on the
back of the unit - the wattage should be listed.
If only the amperage is given (you know the voltage is 120 VAC RMS), so using Ohm's Law, you can calculate wattage:
Watts = 120 Volts X Amps
May 13, 2011 | Sharp R-2A48 Microwave Oven
Le moteur de mon aspirateur duo vac model 3200 refuse de démarrer, cette aspirateur à plus de 10 ans et a toujours fonctioné, La semaine dernière le moteur a...
Bonjour M. Grenier, le probleme ce situe dans la carte électronique de votre aspirateur central Duo Vac. C'est probablement le relais qui est défectueux. Il peut rester en position ''on'' ou autant en position ''off'' lorsqu il devient capricieux. Contactez nous au www.aspirateursenligne.com pour des renseignements et les pièces
Bonne chance
Nov 16, 2010 | Microwave Ovens
I need a phone # or an address to order a manuel for a black and decker all in one breadmaker model#catB1550 type1 600 watt 120 volts 60 hz
Customer service information: Please contact with comments, questions or concerns at 1,800,231,9786 (Monday - Friday 8:30 AM - 8:00 PM ET
Aug 25, 2010 | Microwave Ovens
How big is microwave MMV4184AAB
From page 5 of the owner's manual:
OVEN SPECIFICATIONS
Power Supply 120 VAC,
60 Hz
Input Power 1,500 W
Cooking Power 1,000 W
(IEC 60705
Standard)
Frequency 2,450 MHz
Rated Current 13 A
Outer Dimensions 2915⁄16" x 167⁄16"
(WxHxD) x 155⁄8"
Cavity Volume 1.8 Cu. Ft.
Net Weight 60 lbs.
If you've misplaced yours, you can download it here.
May 30, 2010 | Maytag Microwave Ovens
Model 26961 rated 13 amps. about how many watts would that equal?
the unit has a rating usually on the inside label ior the door somewhere...
you know the voltage allready... 120... multiply the 13 amps x the voltage... and presto 1560...
you can multiply that by .707 and get the RMS value... 1102
so I consider the microwave to be a 1000Watt unit... pretty easy... bu8t you wonder where did I get the numbers... like .707...
It's to compensate the peak to thr RMS... root mean square... lets just call it "Average"
May 06, 2010 | Sharp Model: KB6025MK Microwave Oven
Voltage difference
Actually the voltage is the same, it's the frequency which is different. Running 60 cycle equippment on 50 cycle current is usually no problem. Most noticeble difference is that motor rpm will drop (by about 15%).
Charlie
Aug 20, 2009 | Microwave Ovens
Microwave Ovens Logo
439 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
