Cars & Trucks Logo
Posted on Oct 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Exclamation light on inside board like this [!]
Exclamation light on board
Anonymous
Level 3:
  • Master 543 Answers
  • Posted on Oct 19, 2009
Anonymous
Master
Level 3:
Answers
543
Questions
0
Helped
274401
Points
1601
HI,
well its either one of two things,either its the low tires pressure warning light,which i would set all tire pressure to correct pressure and see if it goes off,and the second is the low brake fluid light,,check the resivor and top off if needed,sometimes when the brake pads are low the resivor gets lower and sets the light,,check the front and rear pads if low replace them and then check level
Toyota celica dash board red light light comes on looks like a pan with steam symbls coming outt steaming pan is it the breaks or catalatic converter heating up
There is no warning light for catalytic converter heating uo. Brake light usually is a exclamation mark inside a circle inside parentheses. What you are describing sounds more like a temperature warning light for the cooling system.
Orange light that looks like an exclamation point inside of a light bulb in 2007 sequoia
It's actually an exclamation point inside of a flat tire symbol. It's your auto sensor for the air in your tires indicating that they need air. Check the spare too as that tire is on the sensor as well.
Jeff
1helpful
2answers
I have a light on my dash with an exclamation point enclosed in what looks like parenthesis with verticle lines underneath. It's yellow. Do you know what it is?
If it looks like a deflating tire with an exclamation mark inside, its the check your tire pressure light.
If its a triangle with exclamation mark inside its the check engine light.
1helpful
Exclamation point warning light came on...what
A yellow explanation point symbol on the dashboard typically applies to the Tire Pressure Monitoring system. A thick ! inside a half drawn flat tire symbol to be complete and comes in yellow color when lit. Under normal vehicle set-up, if this indicator stays lit after the power-on selftest, you need to check your tires for any uneven pressures and adjust their pressures to correct specifications. Okay? : )
A red exclamation point inside a circle when lit indicates your parking brake is on, or your brake fluid level is low.
1helpful
Caution light on dash board
red triangle with ! is the vehicle stability control not the ebattery prolly a bad sensor
Exclamation light stays on on the dash board what is the meaning
my exclamation light turned on in my 05 nissan pathfinder what does this mean
Lightbulb with exclamation mark inside????
This means you have a light buld not working some where in the front or rear lights.When you fix the problem the light will automaticy go out hope this helps.
Top Infiniti Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Infiniti Expert? Answer questions, earn points and help others
