Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Flashing when first turning on
When first turning unit on screen flashes and then straightens out.Is this a bulb problem or does anyone have any solutions
  • 373 Answers
The only thing I would look for is a capacitor that is raised on the top of it: suppose to be flat; and I would look for fluid leaks out of a bad capacitor. Look in the power supply board that takes in the power cord. Hope this helps
Posted on Dec 29, 2007
    Genius:
  • 1,153 Answers
It definately could be having a problem.
How to fix rapid flashing turn signal when all bulbs are OK?
Easy way to find the location of the flasher unit: Turn on either the RIGHT or LEFT indicator, and listen for the click under the dash. When you find the source of the click, THERE'S THE FLASHER UNIT! :)
May 13, 2015 | Cars & Trucks
2004 buick lasabre, right side turn signal blinking fast.
Check the front turn signal bulbs. This will affect the resistance in the circuit and cause the working light to flash at a much faster rate.
Aug 15, 2012 | 2004 Buick LeSabre
Where is the turn signal flasher located for a 97 cadillac deville.
to the left of the steering collum connected to the under collum kick panel as you take the panel down it'll be connected to the cover, It's not a genaric flasher, it's square and looks like a relay585157684.jpgCost about 6 bucks at the parts store. If the turn signals aren't flashing and they do come on, and may be they flash on one side and not the other then it's not the flashers fault. All the light bulbs have to work or it won't flash and thats how you know that thiers a bulb out. Turn on the four ways flashers (Hazard lights ) and walk arounf the car and see if thier all working and flashing brightly. They'll flash anyway on four way the switches are known to hang in hazard and not work right on turn signal so try switching ti a few times and maybe it'll straighten out. If it flashes at all the flasher is good and if they don't even light not on hazard or turn the flasher and or the fuse is bad.
Sep 17, 2010 | 1997 Cadillac DeVille
Blinkers is flashing real fast. Cked fuses and that is not it . What else could it be?
check all the flasher bulbs if one is not working or is faulty the flasher will flash fast change one bulb at a time only,,,,if all the bulbs are good after testing them you need to change the flasher unit as its gone faulty
Aug 14, 2010 | 2007 Chevrolet Avalanche LTZ
When I power up my monitor the display briefly flashes on - to the login screen - and then the display goes blank. If I use the power switch to turn the screen on and off the same thing happens - brief...
Open the monitor, look for blown capacitors and replace them. If problem persist, test the light bulbs and the inverter. If the inverter includes ceramic capacitor, replace it. If some of the bulbs does not do the flash - replace it. Check the transistors of the inverter. Replace if faulty.
Aug 07, 2010 | Dell Computers & Internet
Looking for location of turn signal breaker unit, left turn signal flashing rapidly
its not the fuse, its either the front or rear lamp is out on that side left or right, or if pulling a trailer you need a heavy-duty flasher unit because this makes the same kind of fast flash problem due to more lamps operated at the same time
Sep 25, 2009 | 2005 GMC Savana
My check engine light does not flash when i turn key before start
bulb is probably blown... you have to remove the instrument cluster to change the bulb
May 14, 2009 | 1996 Lincoln Town Car
LEFT TURN SIGNAL FLASHING TOO FAST
when a turn signal indicator flashes faster than is normal it is your vehicles way of telling you there is a problem with the lighting system, do a visual check of your turn signals and you will find a burned out bulb. just replace the bad one and it will return to normal
Apr 26, 2009 | 2001 Nissan Maxima
Turn signals
first check the bulbs then start at the wiring behind the bulb holders with a test lamp
Sep 07, 2008 | 1991 Toyota Camry
TLP-B2 projector lamp problem
my suggestion that unit is faulty and i recommend that you bring to the service center for repair that unit.
Jan 28, 2008 | Epson LCD PROJECTOR, XGA, 3500 ANSI, 1024...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
20 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
