Question about KitchenAid KESC307 Electric Kitchen Range
How to Dismantle Oven Door to Clean Glass
The oven door has greasy streaks or drips inside the glass. Anyone know how to take the door apart to reach and clean this glass? TY
  • tremblg Jan 13, 2008
    Same, I need to dismantle the door to change the inner glass. I have taken the srews out of the bottom part of the door and the inside plate, with the inside glass, can be raised from the bottom up but I can't take this part out. It seems the front is held by screws or some retainer that I can't find.
    I need to know how to dismantle the range door. (Kitchenaid KESC307)
    Thanks
    G. T.
Yep but it isn't worth it in my opinion if you want to know i can tell you its a pain and usually you cant get it all off because its baked on but if you want to do it just reply to your own message and ill write procedure in the morning there is about three or four pieces of glass in there insulation all kind of stuff lol -tech17
Posted on Dec 29, 2007
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
How dismantle oven door to clean between glass panels?
The glass is a supposedly sealed unit that should not be removed for maintenance. This is a common failing of ovens with glass panels.
Mar 03, 2013 | Jenn-Air JGS8860BDP Stainless Steel Gas...
THE GLASS ON MY OVEN DOOR IS STREAKED. CLEANER/CONDENSATION HAS GOTTEN UNDERNEATH GLASS. DRIVES ME CRAZY LOOKING STREAKED. ANY SUGGESTIONS? THANKS
usually there is some way to take either the handle off of the door, or take the door apart from the inside and you can seperate the parts of the door and remove the glass and clean it and replace everything back.
Jun 22, 2010 | GE Profile JTP18 Electric Single Oven
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Oct 10, 2009 | Kenmore Ovens
Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
Jul 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
How do I take off the glass on my oven door to clean it?
I have a Kenmore oven and all I had to do was remove the screw at each end of the handle (accessed with the door open) and the very front section just opened up - SIMPLE!! Wiped it down put the screws back in. Did it all by myself - just have your cleaning cloth in reach before you start. Can't believe I looked at those drips for years and it was that simple!!!
Mar 21, 2009 | Maytag CWE4800A Electric Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid KESC307 Electric Kitchen Range Logo
699 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
