Question about Audiophase MDP-1 Personal MiniDisc Player
Charging battery How do you charge the battery? I have tried...it shows that it's charging, but then the player does not take the charge. A nyway we can get refunds on these things?
  • mrwill_1966 Dec 29, 2007
    I plug in the mp3 player into computer to charge and it never charge, how do I charge the battery?
  • johnsmarie Jan 02, 2008
    I've plugged it in for various times....15-20 minutes seems to charge it 1/2 way. An hour, the same amount of time....3 hours - the same...overnight, the battery says low! How long does it take to charge and how long is the life of battery? If my computer goes into sleep mode, is it still charging or draining the battery? I need help!
Is there a on/off switch? is it on off? slide it over to on and it'll charge.
Posted on Jan 01, 2008
Battery has gone dead and wont turn on to take charge
If its not getting charged, please change the battery with a new one or you can trick, you can show some heat to the battery, which makes the battery for use of charging. But it wont be useful and effective as it is a work around solution. Please use a new battery and try charging.
Thanks
Apr 01, 2012 | Sylvania SMPK 8099 Video MP3 Player
I have an iq sound 4700 that i bought two days ago but it seems that its taking longer to charge.whenever i take the plug out, i cant switch it on. need help ASAP?
dear, you do not mentioned that how long stand by your battery gives you after charging.
and if your mp3 every showed battery full after charging.
well since your mp3 player is new, it must not have any problem in battery, i think your charges has some fault. Go to the shop where you purchased your mobile.
they may make it for free.
well,
if your battery shows charged full, and gives a long stand by, then your battery is 100%good.
you need to change your charges, or an integrated circuit which help to keep charging you mp3 player., this circuit defines how long it have to take to charge you mp3 player.
best of luck!
regards!
Jul 22, 2011 | Bell Technology IQ Sound SC-2528 MP3...
It doesn't recharge the player battery doesn't show that the player charge statuse doesn't show any change please help me to solve this problem
You have not stated the make/model of the set in question but please make sure that the charging adapter or the circuit is supplying enough charging current to the battery .
So use a multimeter and check the voltage when the charging takes places, check the battery voltage, if there is no charging voltage or the current ( if you use a series test in high range) then the adapter is faulty. If charging voltage and current is present with no charge retaining then the battery is faulty.
Mar 26, 2011 | Garden
My computer will not recognize my gigaware 4GB video mp3 player and when i plug it into the computer a battery pops up on the mp3 player screen even though it has been charging for one day and i can not...
I'm not with this brand specifically, but it does sound a lot like the iPod so I will try to help...
Even though the battery is most likely fully charged, it will continue to show the battery symbol to show that it is charging/charged. Depending on the brand, there will be a different symbol between a charging battery and a charged battery.
As for your music, make sure you have the most current driver(s) installed on your computer.
Also try searching FixYa for similar problems.
http://www.fixya.com/support/t1437950-gigaware_4gb_mp3_gx400_4_420
Feb 28, 2011 | Audio Players & Recorders
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
Cannot charge
SONY NWZ-E436F DIGITAL media player | PROBLEM : my battery was low So i tried charging it by connecting the usb to my computer...it charges for 3-4 seconds till the time it shows do not disconnect the moment it shows connecting it shows the battery sign full.... i tried it again and now it has hung and i try to put it on it just shows every moment has its music...and the battery is still low i believe it doesnt go further
Jun 25, 2009 | Sony Audio Players & Recorders
SAMSUNG YP-Z5 PLAYER NOT CHARGING!
U HAVE 2 RESET IT WIT A LEAD PENCIL IT AT THE BOTTAM IN THE BACK OF THE MP3 PLAYER™ IF THAT DONT WORK I DONT KNOW
Jan 07, 2009 | Samsung YP-Z5 MP3 Player
I pod problems
Hi
I think your battery may be going bad or you need to purchase a wall charger to fully charge your battery. Charging your iPod on your computer works fine for a while, but as the battery gets older, it needs more charging and often it doesn't get enough from the computer. Try a wall charger first. Charge it all the way up until it stops charging. If it still shows a low battery you need to have a new battery. There are a lot of places that can do it. Hope that helps.
Dec 20, 2008 | Apple iPod MA446LL/A MP3 Player
Mp3 player wont turn on...its been charging for days..
Never overcharge a li-ion battery. You must firstly 're-set' your T8 (refer to your manual, or download a manual from the Samsung website - download centre). Disregard the charging indicator, as this will always show 'charging' when connecting to a pc. If out of warranty, then you may be faced with new battery, as it is possible to fry a battery if left too long. If under warranty, then seek advice from approved Samsung service agent.
Jun 30, 2007 | Samsung YP-T8 Digital Media Player
Audiophase MDP-1 Personal MiniDisc Player Logo
70 people viewed this question
Top Audiophase Audio Players & Recorders Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you an Audiophase Audio Player and Recorder Expert? Answer questions, earn points and help others
