Question about Jenn-Air JED8430 Electric Cooktop
Jenn-Air Electric cooktop
My front right burner would only operate in the high and off modes. I replaces the burner control element and I still have the same problem.
I am looking for HELP!
Did you replace the limiter the long rod that goes across the element or just the element everything i can find says that's the culprit
Posted on Dec 29, 2007
I have obtained a replacement element Whirlpool AP5653770 for my Jenn-Air JEC8430ADS cooktop. I have lost the secmatic I made showing the colopr of wires going to each position on the element. I have a...
This is the correct way to wire the right front burner on Jenn-Air JEC8430ADS cooktop. Let's do the red wires first. The red wire that comes from #2 on the switch goes to the common connection for the element that should be labeled 2a. The other red wire goes to either of the "b", hot surface indicator switch contacts and the black to the other. Use 1b or 2b for these connections whichever reaches easiest. The yellow wire goes to the inside loop of the burner and the tan to the outside element.
Dec 04, 2013 | Jenn-Air JED8430 Electric Cooktop
My right front burner has stopped working.
no solution - just wanted you to know that I have had this model since 2004 and had to replace this burner twice under warranty and twice after that. It broke again 2 years ago so I just cook without it now. Will be replacing the cooktop and am resolved not to buy Jenn-Air/Maytag/Whirlpool products again - convinced it is a element design problem.
Feb 26, 2011 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
One element will only work at high heat. Is this
replace the control sw for that burner / a very common problem. I would have a service tec do is / unless your good at electrical .. mm
Jul 14, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
I have a Jenn Air JED 8230 cooktop with a bad heating element
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Jun 28, 2010 | Jenn-Air JED8230 Electric Cooktop
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
When the larger burner on the right is on high is melts the plastic control nobs. How do I fix it? Thanks Jim
These burners are not supposed to be operated uncovered. If indeed the burner is covered and it is still causing the controls to burn than the resistance for that burner is failing and the burner should be replaced. Thank you, Dana
Oct 06, 2009 | Jenn-Air JED8430 Electric Cooktop
2 right burners on my Jenn-Air JEC9536 cooktop stopped working.
I have a JEC9536ADB electric Jenn-Air Cooktop. We replaced the class top and now the knobs are all spliting and won't work. 2 of the main burners will only heat in the "high" position? What do I need to replace?
Sep 25, 2009 | Jenn-Air 35 in. JEC9536 Electric Cooktop
Jenn-Air JED8345 one burner does not come on
The switch for the burner is bad and needs to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jun 25, 2017 | Jenn-Air JED8345 Electric Cooktop
JEC9530, dual element burner(right front) does not work the light does come on, the burner does not and the knob has play in it.
This coulb be either the switch or the burner. Either can be tested with an ohmmeter if you can read the wiring diagram. Hope this helps!
Feb 26, 2009 | Jenn-Air JEC9530 Electric Cooktop
Tripping breaker
Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
167 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
