Uniden TRU9488 Corded / Cordless Phone
Problem for Uniden TRU9488 Corded / Cordless Phone
Resetting the Handset
By munchkins2 on Dec 29, 2007
We just purchased a Uniden TRU9488 w/3 handsets. Handsets were pre registered at factory but in error I deregistered handset #1. Cannot understand how to reregister it. The screen keeps saying "Place handset on base for registration or refer to owner's manual. Cannot get anyother info on the screen. Help.. Please contact Melena McMillan at the following: (360)455-0566 or at E-Mail: mmcmelena@comcast.net
Clarification Request
Posted by richly on Jan 30, 2008
How do I reset this hand set
Best Solution
posted on Oct 02, 2008
Very Helpful)
Acadrepro
Rank: Apprentice
Rating: 90%, 5 votes
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Was this helpful?
Yes
No
Solution #2
posted on Feb 15, 2008
Not Rated)
unimax
Rank: Apprentice
Rating: 0%, 0 votes
First make sure you clear the registration on the problem handset. Go to the handset, menu, select de-register; and select yes. Bring your handset next to your base, on the base unit menu select register handset. On the handset, hold the # for 2 seconds. You should see registration completed. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Uniden TRU9488 Corded /
Questions and Unsolved Problems for Uniden TRU9488 Corded /
Do you recommend Uniden TRU9488 Corded / Cordless Phone?
Answer
Answer
My Uniden PowerMax 5.8 GHz telephone shows ''In Use'' blinking, which is supposed to happen only... (More)
Answer
The center button doesn't work anymore. How can I get it so I can look at last caller or the phone... (More)
Answer
ok this chick calls way to much and its just not cool how do i block her?
Answer
Base unit screen is blank and the cordless will not work
Answer
Hello, can anyone help? Uniden TRU9488 hand held set display face lights up,phone rings everything... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Phones Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
