Question about SanDisk Sansa e250 MP3 Player
Songs still on player
My mp3 player was freezing, so I decided to delete all the songs on it to clean it up. I had a lot of kids songs for my daughter. I wanted to put just the ones I like in it, but when I deleted all the songs 119 songs are still in it and the media player doesn't recognized that. Now I don't know what to do. Does anyone have the same problem?
  • ritza Dec 29, 2007
    I'm still having the same problem. I don't know how to get all the songs off the mp3.
Hi, ritza again
I have a new problem. I lost my disk for installing my device. So, I went to the devices website and downloaded their software and no problem. However, somewhere along the line my device was plugged in and now its stuck on refresh database. I been able to turn it off and restart it, but its still stuck on refresh database. I tried taking out the battery and still its stuck on refresh database. I don't know what to do! help!
Posted on Apr 09, 2008
Hi, I'm ritza and yes I had the problem and posted it on 12/29/07. Thanks for your response and your absolutely right. However, I have a friend that is a computer tech repair guy and he told me the same thing you did, except his way is a little easier. He said plug in your device and then go to my computer and you should see your device there. Once there right click on the icon and it takes you to format and it resets the mp3. Again thanks alot for your response.
  • 8,596 Answers
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Posted on Apr 08, 2008
Discovery Kids MP3 player - How do I load songs onto it (or at least reset it and start over...)? When I hook it up to my computer, it didn't register the songs I added, so I went back in and deleted...
Had the same problem. I did a little digging in the file structure on the player. There are a couple of hidden folders, one of which is called ".trashes". When you delete a file on the disc is just places it into this hidden folder. It never actually takes it off the player. I used the Disk Utility app in OS X to format the drive, which cleared out the unwanted files. All the hidden folders stayed in place. Then I had to re-create the "Kids Mp3 Boombox" folder and put in the songs I wanted. Everything seems to be working fine now, but I imagine I will have to repeat this process any time I want to remove a song. Its probably a lot easier to just buy an SD card and use that!
Dec 26, 2010 | Toys
I have always been able to sync music on my Sansa MP3 player until today. It wont accept any new music, but the music files are not hidden. When I try to sync the music, it gets about half-way through a...
Freezing up while playing songs Check and see if there is a boot file in any of the folders on the player use the Explorer to check Check both MTP and MSC modes and unhook your player
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa. http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
Jul 01, 2010 | SanDisk Sansa e250 MP3 Player
My sansa e260 is displaying REFRESH DATABASE and the process continues so that no action can be performed.only a white light displays on the screen until the battery gets low.and a blue light displays on...
freezing at refresh database means there is a wrongly formatted or corrupt file tht you are attempting to put on your mp3 player. to fix this you simply delete whatever corrupted file it is. i, personally, had to go to settings on the mp3 player and at the bottom of the list is "format", i had to format which deletes all ur songs but fixes freezing problem. u only have to do this if you dont know what song is freezing it. if you do know, then you can go into your mp3 file folder under my computer( removable E:) and delete the song from there or you can delete it from your mp3 player via windows media player. to be ensure tht it never happens again you should just put each song on 1 at a time, disconnecting it after every 1, if it freezes again you know what song it is and you can simply delete it. i know this seems like it would take 4ever, but having to go back through and reformat every sinmgle time this happens would take even longer, so just stick with it. hope this helps
Dec 26, 2009 | SanDisk Sansa e260 MP3 Player
When deleted songs, I have deleted everything. so now I have no
you can get a data recovery program to get the songs back do a google search
Mar 29, 2009 | Visual Land VL-340 MP3 Player
How do i delete songs off a gpx mp3 player
You can plug it in, view the files, then right click a file you wish to delete.
Or move the file to a folder on you computer if you want to save it.
Jan 06, 2009 | GPX MW3836 MP3 Player
Can't delete songs
Reformat the player.
Sep 07, 2008 | GPX MW3836 MP3 Player
Deleting all songs from the mp3 player
go to my computer and click on your device and go into music and delete from there
Mar 06, 2008 | RCA H100 MP3 Player
MP3 Player
i dont know if this will help but i think it is Nefertech
Jan 19, 2008 | Nefertech Diamond MP3 Player
Iriver doesnt play songs any more...
I had the same problem and i fixed it by updating the iriver firmware
Jan 30, 2007 | iRiver H10 MP3 Player
It Freezes Someone Help Me Please
This is important; because, if you cannot get into Recovery Mode, then this is a sure sign of a bricked player. You could try a forced hard reset by going in and disconnecting the battery, but chances are, the player is bricked.
Oct 28, 2006 | Creative Labs ZEN SLEEK MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
