Question about Pioneer PDP-5060HD 50 in. Plasma Television
Screen frozen Small gray box at bottom of screen says PLASMA DISPLAY STARTING UP. PLEASE WAIT. The rest of the screen is black. The TV will turn on and off but return to this screen only.
  • AK2008 Jan 03, 2008
    I have just encountered the same problem. Not much that can be done other than switching the TV on/off and changing volume.
    Nothing else works
    Ak
  • Anonymous Feb 02, 2008
    I have the same problem. Did you come up with a solution?
  • 5 Answers
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Posted on Feb 20, 2008
Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Aug 05, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Have pioneer pro-950 hd plasma tv. Has been working great. turned on this evening and got a display saying Plasma Display - starting up. please wait. nothing happens? can't find anything in the manual...
Tries unplug,replug both tv and cable box an hour later.Let the tv reset it self back to the factory setting.The cable box to upgrade it softwares.The tv now should,work again.
Oct 20, 2010 | Pioneer Elite PRO-950HD 42 in. Plasma...
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Jan 05, 2009 | Televison & Video
Help with Pioneer Elite Pro-1130HD 50 inch
just wait it, because it is processing the display data
Nov 16, 2008 | Pioneer Elite PRO-1140HD 50 in. Plasma...
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
BLUE POWER LIGHT
Jan 26, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Cant get picture
Jan 09, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Pioneer PDP-5060HD 50 in. Plasma Television Logo
577 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
