Panasonic NV-DS65 Mini DV Digital Camcorder
Problem for Panasonic NV-DS65 Mini DV Digital Camcorder
Have the moisture indicator flashing. Have had the
By kamelb on Oct 19, 2009
Have the moisture indicator flashing. Have had the tape out and left open for 24+ hours. Tried a silica gel sachet inside,closed up and still have the indicator flashing. Any easy suggestions guys?? Regards, Keith
Solution #1
posted on Oct 19, 2009
Somewhat Helpful)
Abrsvcs
Rank: Guru  Panasonic Expert
Rating: 88%, 1843 votes
This could be a bas sensor too. Open the door of the camera and point a hair dryer at it from about 12" away. Let that run for 5-10 minutes and see if the message clears. If not, then the internal sensor has a bad connection to it or is defective. In either case, the unit will require service. Since the alignment of the internal mechanism is delicate, I would not recommend a self-service attempt.
Please keep us posted on your progress.
Dan
Was this helpful?
Yes
No
Popular Solutions for Panasonic NV-DS65 Mini DV
Questions and Unsolved Problems for Panasonic NV-DS65 Mini DV
Do you recommend Panasonic NV-DS65 Mini DV Digital Camcorder?
Answer
Answer
Will 1200mAh be safe to use for a replacement of previous battery which says 800mAh and 7.2V.... (More)
Answer
how can i install driver and download video recording in the computer
Answer
can i transfer the contents on the mini-dv tape onto the memory card?
Answer
i need to install a driver for a panasonic camcorder on Mac OSx. model nv-ds65. Where can I... (More)
Answer
my lcd is coming out all black. what do i do?? and my scroll botten doesn't work
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camcorders Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
