Question about Canon PowerShot A530 Digital Camera
Memory Card Error - Locked
I have a one year old Canon Powershot A530. It works great for taking snapshots with the 16 MB Memory card it came with. I just bought a new 4 MB Memory Card that should work with it, but I get a "Memory Card Error - Locked" message? What can I do to fix this and How do I do it?
  • brettmusic Dec 29, 2007
    Whoops...I met 4 GB, not MB.....this think has me too flustered!!!!
I had the same problem, i checked the little slide switch but nothing . it still says card error. my new card works fine though
Posted on Aug 11, 2008
  • 589 Answers
Take the card out, and you'll see a little slide switch on the side of the card. It is most likely in the "lock" position.
Posted on Jan 08, 2008
The likely problem is that the BIOS battery (NOT the rechargeable Lithium battery) has run low. This tiny, internal battery can be replaced without too much trouble by someone who doesn't mind disassembly of small parts, otherwise it's best left to a pro.
The battery is available from Canon or an official distributor, such as Huron Camera in Jackson, Michigan.
Check the parts list. If you're squeamish, give Huron a call and arrange to have them fix it.
Posted on Dec 30, 2007
Hi I have a Canon Powershot A530 but if I want to take photo's it says card locked?
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 21, 2011 | Canon PowerShot A530 Digital Camera
Brand new 4 GB Sony memory card. I get a card locked/memory card failure.
The A530 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and won't work. You need to use cards 2GB and smaller with the A530.
Dec 15, 2010 | Canon PowerShot A530 Digital Camera
I leave tomorrow HELP I have a Canon Powershot A530 and when I put in an 4GM memory card I get Memory Card Error
The A530 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it will fit into the slot, it won't work there. You need to go with SD cards 2GB and smaller.
Sep 28, 2010 | Canon PowerShot A530 Digital Camera
My card says it is locked on my canon powershot A530 how do i unlock it?
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 27, 2010 | Canon PowerShot A530 Digital Camera
I try to take photos with Canon powershot A530 but it keeps saying memory card locked. What do I do and what does that mean?
Umm, take out the memory card from the camera and there should be this small lever at the side of the card that shifts up and down. Shift it out of the "locked" mode.
Jul 10, 2010 | Canon PowerShot A530 Digital Camera
Canon camera won't accept SD memory card
It's a good bet that anything 4GB or greater is a SDHC card (look on the card, see if SDHC is written there). Your A530 was designed before the new SDHC format came out. Sorry, but your camera will not recognize this type of card. Recommend instead that you get a 2GB standard SD card. They're relatively inexpensive these days.
Jun 07, 2009 | Canon PowerShot A530 Digital Camera
Camera says Card Locked and I can't Reformat the Memory Card
From the problem described by you, it seem your camera has gone into a internal memory error and hung. Try to take out the battery, the memory card etc , clean and then reinsert and then power on? Try this it might work.... Generally the camera should start working normally once you will take out the battery, since it will reset.
If it still does not work, then think you might need to take it to Canon. They are very helpful and could sort out if you have system software problem. But Before that, I suggest that you must take out its memory stick, the battery etc and keep the camera like that for about 15 minutes. Then only reinsert the battery (fully Charged) and then try to reformat the memory card. If you are lucky, you might not need to go to Canon. Best of Luck.
Apr 30, 2009 | Canon PowerShot A530 Digital Camera
Memory card error
Check the slot and see if the pins inside are fine, no breakages, free from dust etc. Try turning the camera on and off (completely remove batteries etc).
Mar 03, 2008 | Canon PowerShot A530 Digital Camera
Canon PowerShot A530 Digital Camera Logo
255 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
