Question about i-mate JAQ Pocket PC
Connecting to bluetooth
I ve new imate jaq that have problem that it unable to connect bluetooth device,
steps it did, ON both, the bluetooth in pda and headset,
run "new device" in pda but it didnt find anything.
the headset is working on another pda, so that mean the problem is in pda
im waiting for good reply
  • Xmen_xwk Dec 30, 2007
    Still need a solution for this problem?
    Try our Premium Assistance plan
    hahahaha, good joke, i will try your premium then there is no guaranty of the solution, instead of the free online support of imate
  • 147 Answers
Restore your PDA to factory defaults and try to make the connection again. I think it will work.
cheers
Posted on Jun 25, 2009
Conection of GPRS
Download imate-configurator from the imate website.
Go to: http://www.imate.com
  1. Enter your country name
  2. Select "Support"
  3. Select "Device Support"
  4. Select "Your Phone"
  5. Select "Patches"
  6. Download i-mate configurator
install the cab file in your device, the settings will automatically be done.
You may then connect to the internet.
Please rate if this helps you...
Jul 23, 2009 | i-mate JAQ Pocket PC
Tip
Hi, i got new Imate-jaq. I am facing problem in synchronising the imatejaq with...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Dec 28, 2007 | T-Mobile MDA
Hi there, I Like to upgrade in my I-Mate JAQ OS WM 5 TO OS WM 6,1 or 6,5 if its is possible.Please show me how to do this. Thank you, Aleksandar
Hi, I'm afraid there is no offical or unoffical ROM upgrade for your PDA yet (ROM is the place where the PocketPC operating system is stored, and each device model has a different ROM so sadly you cannot use any other Windows Mobile 6 ROMs with your device.). I am giving more details about this issue to make it clear. Still you can follow the forums time to time to check if someone makes a ROM for your PDA. Basic problem is unlike most of the PDAs, your PDA is a non-HTC based PDA. I hope this helps. You can still download some PDA software to use your device more efficiently (Most of the PDA softwares are designed for working on both WM5 and WM6, since your device uses WM5, you won't be having a problem.).
Details of your PDA: (http://www.pdadb.net/index.php?m=specs&id=587&view=1)
Unoffical ROM forum: (http://forum.xda-developers.com/showthread.php?t=349007)
Offical ROM website: (https://www.imate.com/Support_DeviceSupport.aspx?key=48fc9a97-1b91-4350-919d-b4dfdbcb6cbd&cmd=roms)
Apr 18, 2009 | i-mate JAQ Pocket PC
Imate jaq having problem to connect the pc
I have problem to conect with my PC with imate jaq so p/l let me know at ashok_manandhar@hotmail.com
Sep 07, 2008 | i-mate JAQ Pocket PC
GPRS setting for Imate JAQ
i have aitel sim card. please give guide for internet mobile office setting
May 21, 2008 | i-mate JAQ Pocket PC
INTERNET SETTIN
on your i-mate JAQ go to programs>internet sharing>connect.
prior to this pl make sure that your pda is connected to ur desktop via USB cable and it is synked with the desktop.
rgds,
May 10, 2008 | i-mate JAQ Pocket PC
Issue with imate JAQ
Dear Have u got ur GPRS or EDGE service activated from AIRTEL. Pls confirm it, if yes then following are the settings for airtel.
go to
>>START>>SETTINGS>>CONNECTIONS
connections>>Add a new Modem connection
>>Enter name-airtel or Mobile office
>>select a modem>>it should be Cellularline (GPRS)
>>NEXT
>>eNTER THE NAME AS IT SHOULD BE DIALED
>>enter airtelgprs.com (all small caps)
>>NEXT
>>FINISH
NOW again go to START>>SETTINGS>>CONNECTIONS>>connection>> Advanced>> select networks
There will be two options
1-prog that automatically connect to the internet
2-prog that automatically connect to a private network
>> for both options select >>My ISP
>>tab OK
Feb 29, 2008 | i-mate JAQ Pocket PC
I-mate jaq
my imate jaq doesnt connect to my pc. Is this a problem related to drivers. If yes, then I suppose the installation cd does contain a driver please advice.
Jan 18, 2008 | i-mate JAQ Pocket PC
Synchronise and connection problem in Imate jaq
hello! pradeep
let me tell u if u r using windows XP as an operatin system
then activesync creates some problem it is better to download activesync 4.5 which is the latest one and your problem will be solved. you can download it from net...
Dec 28, 2007 | i-mate JAQ Pocket PC
Installation in my laptop for internet access
i am unable to use my i-mate as a modem to acess internet by using my computor wimdowxp
Dec 24, 2007 | i-mate JAQ Pocket PC
i-mate JAQ Pocket PC Logo
116 people viewed this question
Top i-mate Computers & Internet Experts
iphone service
Oloyede Monsuru
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
