Question about HP LaserJet 1500L Color Printer
Cartridge leak Whenever the cartridge T-132 is refilled, the ink leak badly. How can I stop the leak ?
  • Col NR Kurup Dec 29, 2007
    You havenot givenme the solution
    My problem is not solved. I have purchased 6 months back from Abu Dhabi an HP Printer "HP PSC 1500 All-in-One series" My present problem is that its cartridge "T-132 Black" is not available in Kerala. My only solution is to recycle the used cartride. But when ink is filled it leaks badly that by the time I reach home hardly any ink left. Can you kindly help me so that I don't have to throw away my 6 months old brand new printer just because I cannnot get ink
    Col NR Kurup
    Deepam, Mutteri Madham, Chettemcoon,
    Tellicherry 670101, Kerala, India
    colnrkurup@gmail.com
    Problem Solver:
  • 15 Answers
  1. you didnt pay to have attention
  2. dont use recycled if you dont want problems
  3. this problem area is for a laserjet 1500l printer it does not use ink it uses toner
Posted on Dec 29, 2007
Alignment problem. just refilled black ink cartridge..seeing message that printer is not aligned and remove tape from cartridge, but i see no tape
1) remove the cartridge and check it is not leaking. If it is, the printhead area on cart will be flooded with ink. Removing couple of ml from cart will stop it leaking.
2) If the cart looks clean (not leaking), stamp the printhead on some folded tissue paper or paper towell. It should leave a solid black stripe about 10mm long on the tissue. If it doesn't, your refill ink hasn't quite reached the printhead. You can blow little air into the breather hole (on top) to prime the printhead. Stop blowing when ink starts leaking at the printhead.
Clean the cartridge up before installing it.
3) If all above is ok and it still doesn't align properly, repeat above steps with the colour cartridge. The printer needs all colours working to perform the alignment process.
good luck with it
LC1000
www.inkbank.com.au
Dec 10, 2010 | Lexmark X7350 All-In-One Printer
After refilling ink cartridge no ink registers in the cartridge and will not print
you may have a bad head on the cartridge. you should only refill the a few times as the heads get bad on the cartridges after a while. i stopped refiling and just but them you are not only playing for the ink but you also pay for the print head on the cartridge and there not that much/ or have a retailer refil it for you but they will only do it once per cartridge.
Jun 30, 2010 | HP PSC 1610 All-In-One InkJet Printer
How to refill ink in hp blck cartridge
  • Purchase an ink refill kit at an office supply store. (Staples, Walmart, and Costco all carry this inexpensive kit. It usually costs about half the price of an average printer cartridge.)
  • Gather your kit, a roll of paper towels, and some clear scotch tape together on a large flat working surface, a table or desk.
  • 3Remove the empty cartridge from your printer. (Remember to close your printer lid or door while you are working.)
  • 4Cover your hands with a pair of disposable plastic gloves while you work with the messy ink.
  • 5Take a paper towel and fold it in half twice. Work over the paper towel to catch any leaking ink.
  • 6Place the empty cartridge on it.
  • 7Read the instruction manual included with the refill kit to learn how to refill your particular type of cartridge. (The following instructions are just a general guide).
  • 8Locate the fill holes on the top of the cartridge. The depressions can be felt by rubbing your finger across the label.
  • 9Use a sharp pencil to pierce the refill holes in the top of the ink cartridge. (Correct places can also be found in the kit instructions).
  • 10In addition to black, there are three colors of ink: magenta, cyan, and yellow. Follow the kit instructions on which hole to insert each color OR push a toothpick into the holes to identify the colours as markings on the printer cartridge are sometimes there to fool you into putting the wrong colours into the cartridge ink chambers.
  • 11Insert the long needle on the refill ink bottle into the correct hole.
  • 12Slowly, add the ink. Carefully watch to be sure that you do not over-fill.
  • 13Stop quickly as soon as you see a bit of ink oozing out of the hole. Without letting go of the bottle, slowly release the air, sucking a little ink back out of the ink cartridge, before you remove the needle completely.
  • 14Carefully daub the cartridge contacts on the paper towel, you should see a splotch of the ink leaking out onto the paper towel.
  • 15Cover the hole with a small piece of clear scotch tape. (This works better than the seal dots included in the kit.) Make sure that no ink is leaking out of the top holes. (That's where the clear tape comes in handy.) Be careful not to cross contaminate the colors.
  • 16Repeat steps 11-15 for each ink color.
  • 17After you have refilled all three colors, carefully blot (don't wipe or rub) the cartridge printhead on a folded piece of paper towel. You may need to do this several times. Do this until it stops bleeding and you see an even stripe of three colors showing up on the towel.
  • 18If the blot shows the colors either faded or not at all, blot on wet paper towel and again on dry, to get the ink flowing.
  • 19Replace the ink cartridge into the printer. Never, ever install a leaking print cartridge.
  • 20Immediately print something, anything, just to get the ink flowing. Print several test pages, preferable photos with a lot of different colors.
  • 21Follow the cleaning or priming cycles for your specific printer.
  • May 25, 2010 | Office Equipment & Supplies
    I bought ink refill, how do I get the printer to accept it?
    HI Pauline, I have used ink refills in the past and they are bad news, they are painful refilling the cartridge and will mess up your printer with small leaks, I advise you to buy a new cartridge from the printer manufacturer or a proven generic cartridge for your printer. I hope this help you. Let me know.
    WBTech
    Feb 09, 2010 | Lexmark X2500 All-In-One Printer
    Refillied black ink cart. causes error.
    The ink cartridge is bad get a new one after a few times of refilling the ink cartridge they go bad. Hope this helps ya
    Cheers
    Johnthetr870
    May 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
    You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
    Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
    When I print, black ink comes out over the page
    what printer is it and is it using ink/cartridge? Try taking out the ink and check to see if its leaking or anything like that. Clean the printer and print a couple of pages to see if the problem is resolved. you may also need to replace the ink/cartridge. good luck.
    Dec 11, 2008 | Office Equipment & Supplies
    Cartridge? problem
    If you are using or have used third party generic ink cartridges or refilled ink cartridges, the Cartridge Sensor printed circuit board may have been damaged. We have found that some third party generic ink cartridges leak onto the ink cartridge sensor circuit board causing an electrical short of the ink cartridge sensors. The damage from the leaked ink results in the machine displaying NO CARTRIDGE because the machine will no longer recognize the installed ink cartridge(s). Genuine Brother ink cartridges do not cause this issue because of the unique design developed to fit specifically in the Brother products. As long as a Brother cartridge has not been refilled, the Brother cartridge will not leak.
    Jul 07, 2008 | Brother MultiFunction Center MFC-440CN...
    Flashing ink refill light
    Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
    Feb 28, 2007 | HP DeskJet 810c InkJet Printer
    HP LaserJet 1500L Color Printer Logo
    235 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
