Question about Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum
Hoover u8147-900 upright vacuum
When i set the vacuum to carpet so the brushes will spin, it makes a horrible noise like the agitators are wobbling or the belt drive motor is off center
  • wilkinsrd Jan 29, 2008
    the problem ended up being that the belt drive assembly that i used was just a bit too big and wasn't holding the brushes in place while they were spinning.
    thanks for the response
    President:
  • 1,673 Answers
Either the brush rolls are bad, at the ends, or the gear/motor asm. is bad.
Posted on Jan 29, 2008
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Why does The beater bar on my hoover continue to run in the upright position?
Hi there! Some vacuums do not come with the feature that automatically shuts the brushes off when in the upright position.. If your unit is like this, be sure to put the vacuum on the highest setting when using the hose. Also, because the brush-roll continues to spin, avoid tipping cleaner or setting it on furniture, fringed area rugs, or carpeted stairs during tool use. Hope this was helpful!
Jul 21, 2014 | Hoover Vacuums
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
Nov 02, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Vaccuum Hoover U5763-900 wind tunnel Twin Chamber is barely used. Belt is in tact and agitator is not worn. Nothing clogged. Agitator spins fine off the ground or on hard surface or flat rug. Once on...
It's because the belt is stretched out and has lost elasticity. It can turn the brush in the air but is not tight enough to turn it in the carpet. Replace the belt at least once per year even if the vacuum is never used.
Feb 09, 2018 | Hoover U5753-900 WindTunnel Bagless...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover makes terrible screaching sound when using upright.
It's most likely the bushings/bearings in the beater bar (roller). The beater bar cover is fairly easy to remove -- take it off and investigate. Could be that the roller only needs lubricating on the ends. Also, check the belt to see if it's intact or damaged.
Clean area thoroughly.
If this is not the problem, please, let me know.
Charlie
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt tension adjustment
If you are looking at the belt while the vacuum is in the upright and locked position, the belt will be loose. The idler removes tension so the brush doesn't spin while you walk away and put heat marks in the carpet. Hit the lever that allows you to move the handle low, like you are vacuuming under the bed, and the belt gets tight.
May 25, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Just bought a hoover upright windtunnel cylonic weird noise
no, brush roller shouldn't be touching anything,its under warrenty so take it to a hoover repair shop with your proof of purchase and they will fix it at no cost to you.something like that they might be able to fix it while your there because it won't take long. please leave feedback
Jan 08, 2009 | Dirt Devil Featherlite Bagless Vacuum...
My vacuum does not have any suction, and it spits out dirt when I roll it backwards. It is an upright Hoover Elite
Trouble Shooting guide:
1. Check to make sure that your agitator still spins. (Agitator = brush). If your agitator does not spin, it could very well be a belt gone bad and means there will be no suction.
2. If belt is fine and agitator spin, your vacuum could be clogged. A clogged vacuum can be cleaned with a brush inserted into the hose of the vacuum to pull out the debris.
Mar 07, 2008 | Vacuums
Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum Logo
266 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
