My 7200 quit suddenly and only uttered a slight whine... otherwise dead. Looking for solutions, I found this site and after reading other posts I decided to contact Neo32. I also confirmed on AVSForum his reputation and was not disapointed after having him repair my power supply. The 7200 is back in place, hopefully to give me more years of service. To me, having it repaired was a much better solution then researching a similar projector with a matching throw/screen and rebuilding the ceiling cabinet in the Theatre. Rob
Find wiring diagrams , get a voltmeter an test the electrical circuits , quit reading posts an stop looking for a common problem between all HHR's. Or take it to a qualified repair shop .
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check for cracks or air leaks. These can cause hum/whine/whistles. Spay soapy water solution on the manifold at joints. Avoid spraying anything electronic directly. If the noise suddenly stops, you have found the air leak.
These blink code is fault indication. With Philips brand TVs, we cannot read these blinks as they appear. Means by digits. There is a special procedure to read these blinks. If you wish to get more details about the blinking codes reading procedure to Philips TVs, visit this site. Pull up older posts there. Details are given about how to read these blinks and convert them to numerical digits. Check the site with patience. It has so many posts, and all are related to electronic equipment repair. Check it in 'Timeslide' option. It will be easy to find brands.
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works. 2. Delete all partitions 3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Without knowing where the sound is coming from, theres no way to know if it is important. Is it possible the noise is the ac clutch, and the ac compressor is locking up and killing the engine ?
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please
include your brand name and the full model number from the tag in or on
the unit, your symptoms (dead).
