Question about Samsung RM255LASH Side by Side Refrigerator
Ice dispenser only dispenses barely frozen wet ice.
Our Samsung RS2677AA icw dispenser only dispenses warm wet ice. If we place an ice cube tray in the lower freezer section, we get very cold, not wet ice. Is there any way to make the ice dispenser yield really cold ice?
  • Christa Dening
    Christa Dening May 11, 2010
    what is the temperature in the freezer
Sorry, I made a mistake in respnding to the question. I gave the temperature of the refrigerator because it surrounds the ice maker. The temperature of the refrigerator is 38 degrees and the temperature of the freezer is -2 degrees.
Posted on Jun 15, 2008
We keep the freezer at 38 degrees.
Posted on Jun 14, 2008
Samsung French door ice maker
Sounds like you are getting to much water or the sensor is not Sensing proper temp
Apr 02, 2016 | Samsung Refrigerators
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
My Bosch ice maker has a problem. It has frozen over and does not dispense the ice cubes, the refrigerator thinks it has dispensed the cubes and so try's to fill the ice cube tray up again with wa
Ice makers have heaters that loosen the cubes when time for harvest. Sounds like the heater on yours is bad, or maybe the ice maker itself is just bad. Most likely will have to replace ice maker.
Oct 12, 2017 | Bosch Refrigerators
Ice maker will not change back from crushed ice to cubed ice.
you may not of gotten the metal rod on the bottom of the tray back in the right spot. remove the tray and slide it back in if problem persists you probably have a frozen or failed ice solinoid. this is behind the back wall and engages when you have cubed ice selected.remove the back panel and then remove solinoid and let it thaw rub the plunger with a little wd-40 and reinstall if you don't see any signs of the plastic melted or the p[l;unger remains stuck in the solinoid body. if problem reoccures replace the solinoid
Apr 24, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice dispenser will only give crushed ice; will not dispense cube ice ;I have looked at the auger and chute and nothing wrong there; when I chose cube, it dispenses crushed in both the crushed and cube...
Your selector solenoid is not working. Next to the auger motor there is a selector. You will see a plastic peice in a hole to the left of the auger.....Try to move it up and down. If it won't move it is more than likely frozen in one spot. Try to defrost it. If that does not work then replace the solenoid.
Sep 07, 2009 | Kenmore Refrigerators
PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Nov 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Jun 11, 2007 | Samsung RS2630SH Side by Side Refrigerator
Ice cube dispenser not working
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Jan 02, 2007 | Samsung RS2578BB Side by Side Refrigerator
Samsung RM255LASH Side by Side Refrigerator Logo
509 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
