GE top load washer leaks on floor
After the washer fills with water it instantly starts to drain from under the machine onto the floor. This is before the cycle starts. What could cause this.
    Sergeant:
    Champion:
  • 262 Answers
Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
Posted on Dec 29, 2007
Washer won't hold water, just drains to the floor.
Sounds like there's a hole or loose ejection water hose.
Move the washer so it will run and you can look in the back to see where the water is coming from....fix the leaky problem once you find it. Could be a bad hose clamp as well
Dec 12, 2017 | GE WBSR3140DW Top Load Washer
When filling my Kenmore washer to begin a load of laundry the water enters the tub like it is going to wash but immediately drains onto the floor and the "water sensor" never tturns the water...
This either due to a detached "water sensor"/pressure switch hose or a broken drain/leaking drain pump. Disconnect power then remove the screws securing the console to the top of the machine. Pull the console forward then up and lay it back on the hinges. The screws are located at the rear of the console, front corners of the console, or at the front corners of the console under the end caps.
Click on the link below for the detailed procedure in troubleshooting and repair of this leak problem.
Whirlpool and Kenmore Top Loader Washing Machines Leaking From the Bottom
Aug 20, 2011 | Kenmore 24032\24036 Top Load Washer
Whats wrong with our ge washing machine it keeps draining water,it is brand new just arrived.what do you think is the solutions to our problem. everything is being put together, we already install the...
make sure the drain hose is higher than the washer tub sounds dumb i know but if the drain hose is left lying on the floor going into a floor drain or something it will not fill up
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
Leaking
hello there
Although there are a few leaks common to all brands, most brands have leaks that are peculiar to their design. GE, Whirlpool, Maytag, and others all have common and well-known leak areas. After reading this section, see the chapter about specific brands for details.
A common "leak" zone is not a leak at all; the wall drain backs up and overflows onto the floor. This is commonly misdiagnosed as a leak. It can be difficult to diagnose; the problem may be intermittent. Depending on how badly the drain is clogged, there may be a little water or a lot, or it may only overflow every second or third load. While diagnosing a leak, do not be too quick to write this diagnosis off.
If you suspect that your drain is backing up, but you can't quite ever be there at the right time to observe the overflow, try this: wrap some toilet paper around the drain hose just above the wall drain pipe. If it backs up, the paper will get wet. Even if you're not there when it happens and the paper dries out, it will have crinkled up, and you'll know your drain's backing up.
If it isn't the drain, run the machine with a full load. Without moving the machine, get right down on the floor and look under the machine with a flashlight. Try to find the general area where water is dripping to the floor; front or back of the machine, left or right side.
Open the cabinet and look for mineral or soap deposits where there shouldn't be any.
Trace the deposits in the natural direction of waterflow (against gravity or centrifugal force) back to the source of the leak. Fill the machine again and run it through a cycle or two. Be patient; use your eyes and your brains. There is no magic, easy way to detect a leak.
The usual places are:
WATER VALVE: The guts of the fill solenoid valve sometimes will corrode. You may see water leaking from, or rust on the top of the solenoid. (See figure G-7A) Since the valves only open during a fill cycle, this may appear as an intermittent leak. The solution is to replace the valve.
PUMP: Usually from around the pulley seal. Some washer pumps have a hole that allows water to weep out when the seal starts to go bad. The solution is to replace or rebuild the pump.
BLEACH DISPENSERS: Bleach is VERY hard on plastic parts. If the bleach dispenser gets old and brittle, it can crack or break off, and the flush water can leak out.
Figure G-7A: Leaky Water Solenoid Valve
Oct 16, 2010 | GE WVSR1060A Top Load Washer
Our GE WSERR417FOWW washer is leaking (profusely)
Any solution to your problem? I am searching because mine started the same behavior tonight. I hope that you found a solution, and would be willing to share it!
Thanks.
Jeff jeffyr2@verizon.net
May 24, 2010 | GE WJRR4170E Top Load Washer
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Water Everywhere
Look for loose, cracked, pinched, broken hoses to and from the water pump or leaks from the water pump itself. The outer drum could have a rust-through that leaks. This can be repaired with epoxy, but the inner drum must be removed to access it. The cabinet top is opened by using a putty knife or similar tool to push straight back under each front corner which releases a spring latch. Sometimes, the drain hose outlet is pushed from the house drain by high water flow. Tie the hose to the drain with tape or cord. Fill the tub with water, then stop the cycle and watch for leaks.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
Some water drains out onto the floor.
the drum seals will need to be replaced. there are seals that are used for the screws that connect the drum to the drive. they are leaking.
Mar 11, 2009 | GE WBSR3140DW Top Load Washer
Water Leak
Yes all you have to do is take off the front cover of the washer or the back cover, it it usually the front on top load washers. I believe your water pump may be cracked, but am not sure. What you need to do is remove the cover and start your washer and let it fill. Get a flashlight and pay close attention to where the water is leaking from. Then all you have to do is replace the part and your done. Any part dealing with water leaking will not be hard to change.
Sep 23, 2008 | Maytag MAV6200 Top Load Washer
Washing Machines Logo
255 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
