Question about Dewalt DC011 AM/FM Radio
Radio works off battery but charger does not work
While the raido works with battery, the radio does not work off the AC power cord and the charger does not work. I have checked the internal fuse but it is fine.
Any ideas?
  • 4 more comments
  • coopsy Jan 20, 2008
    have same problem. The radio works with the battery fine-but it does not work when I plug the cord into the outlet. Check the fuse, that is fine.
  • Anonymous Feb 17, 2008
    Radio works with battery, but doesn't charge or play when plugged in to a 120 volt outlet.
  • redrdyer May 07, 2008
    how do i check the fuss?
    stopped working
  • barry christiansen
    barry christiansen Jul 18, 2014
    i have a dewalt radio charger model dc012wordsite charger/radio output 2.8amps. apparently its been plugged into 220. ive' openned it up an found the two fusses are fine but a little round brown 2 pronge component was open. does anyone know if this saved the transformer '
    barry christiansen Jul 19, 2014
    i guess im asking if there is anything eles that may of blown other that the pri. of the transformer and that suspicious little brown round fuse i belive its about a quarter of an inch in hieght and withth. nothing at all looks burnt or got over heated or anything like that . barry
I cam working on one and the transformers' primary winding is open. You will most likely need part # 429790-48 from Dewalt.
Posted on Feb 13, 2008
Can I power a small appliance with my dewalt
This is what dewalt is saying...The Dewalt 12V/20V MAX work-site charger/radio functions as an AM/FM radio and recharges your 12V/20V Dewalt batteries (batteries not included). The 3-stage charger can recharge your batteries in as little as 1 hour, and the radio can run off 12V/20V batteries for cordless operation
  • 2 AC power outlets offer more versatility for jobsite power
  • Auxillary & USB ports allows for connection to CD, MP3, portable satellite receivers, and other digital audio devices.
  • USB port allows device to be charged via USB when radio is plugged into a wall outlet
  • Class D amplifier, woofers and tweeters provide full range of high and low sound for optimum sound quality,( hope this helps)
Aug 06, 2014 | Dewalt DCR015 MP3 AUX USB 12V/20V MAX*...
Radio will not work on AC
check ac wire & its connecting jack,then step down transformer
Apr 19, 2014 | Dewalt Dc012 Worksite Radio With Built-In...
Will not charge
Check your power supply. If the all the charging cups are not working you might have a bad power adapter.
Feb 07, 2014 | Motorola Cls Multi-unit Battery Charger...
1993 dode ram 250 speedomiter and horn stop working
short probably in the radio. if it is after market radio there is bare wires some were some radios like kenwood when shorted just need to disconnect the power like your key on/off and it will reset
Nov 01, 2012 | Dodge Cars & Trucks
We have an Emerson PD6620 Radio/boombox. For many years, we used the AC outlet to play the component. We tried the battery route with new D batteries (8) and the unit did not work. Is there an AC/Battery...
This 6620 has a small micro switch where the a/c power cord plugs in. It will not run on battery power untill you pull the power cord out of the radio jack.
Jun 28, 2010 | Emerson Audio Players & Recorders
I had to get a new battery and now my radio wont
Feb 01, 2010 | 1999 Buick Regal
Works on batteries. does not work on ac. If you leave cord in it and turn off ac it still will not work, but if you take cord out of the unit it will then work on batteries.
If the AC cord can be removed from the back of the radio, then there is a mechanical lever inside where the AC cord plugs into the radio. That lever will cause the battery connection inside to be open (or disconnected) so that it will run off AC and not blow up the batteries. That is why it won't run on batteries when that cord is plugged in.
If it runs on batteries but not AC, find another cord to try. Most radios use about the same cord. If a second cord still doesn't make it work, it's most likely a fuse inside for the AC circuitry. they are usually mounted on a circuit board inside the radio right near where the AC cord plugs into the radio.
You should be able to take the radio apart (while it's unplugged from AC of'course) and find that fuse. If your good with a soldering iron you can replace the fuse. Replacements can be found at Radio Shack. If your reading these instructions to begin with, your probably not good with a soldering iron and you should just buy a new radio. Good luck.
Nov 26, 2009 | Durabrand CD Player with Cassette...
Raido isn't working. Acts like it's not getting power!
Oct 27, 2009 | 1997 Pontiac Grand Am
Does this charger have an AC cord that plugs into it with a 2-prong end on the cord. If so, you should be able to find the cord at most electronic stores like Radio Shack.
If not, you can buy a replacement charger on ebay or from Amazon.
Dec 18, 2008 | Canon PowerShot SD870 IS Digital Camera
Milwaukee Job site radio
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Dewalt DC011 AM/FM Radio Logo
1,113 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
