Lexmark X5470 All-In-One InkJet Printer
Problem for Lexmark X5470 All-In-One InkJet Printer
How do you clean the rollers?
By marilyncoste on Oct 19, 2009
How do I clean the rollers on my Lexmark 5470? Paper does not pull through feeder since day one. And, how do I get to the rollers?
Best Solution
posted on Oct 19, 2009
Helpful)
Roop1980
Rank: Wiz  Lexmark Expert
Rating: 84%, 221 votes
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle white roller. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Roop 1989. TX for your fast response re my Lexmark 5470 feed/roller problem. Will try to clean it today. " - marilyncoste
Popular Solutions for Lexmark X5470 All-In-One
Questions and Unsolved Problems for Lexmark X5470 All-In-One
Do you recommend Lexmark X5470 All-In-One InkJet Printer?
Answer
Answer
I have installed a brand new colour cartridge into my Lexmark X5470 but it is saying right cartridge... (More)
Answer
Inserted memory card into x5470 printer and cannot save photos to computer.
Answer
Hi my name is Lecette. I am having some trouble printing on my lexmark x5470 printer. When I print... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
