Maytag Neptune FAV6800AW Top Load Washer
Problem for Maytag Neptune FAV6800AW Top Load Washer
Neptune TL, stops at the 11 minutes to end and
By krabby64 on Oct 19, 2009
Neptune TL, stops at the 11 minutes to end and will not go past, I have to shut off, hit spin cycle to finish load
Comments:
Oct 20, 2009
- I have had a small uC error code a few times but mostly it hits 11, stops, beeps, and unlocks. You try to restart it it will jump up to 18 go down to 11 and then the samething again.
Solution #1
posted on Oct 19, 2009
Not Rated)
dh1200s
Rank: Guru
Rating: 94%, 108 votes
Hello krabby64
Is your FAV6800AW or FAV9800AW failing with error codes dc or UC or both to the Console display? If you are I believe you are experiencing a clutch malfunction with your machine. Take a look at this post and see if your problem is similar.
If you have error codes to the display when the machine fails in the last 11 minutes (I believe start od spin cycle) can you let us know what those error codes are?
Comments:
Oct 19, 2009
- Sorry let me try the l link again to the post
Oct 20, 2009
- I would say you have a clutch malfunction, The failing in spin cycle with dc/UC errors will only get worse as the roller clutches in the clutch continue to degrade. If you decide to DIY the fix see this post.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune FAV6800AW Top
Questions and Unsolved Problems for Maytag Neptune FAV6800AW Top
Do you recommend Maytag Neptune FAV6800AW Top Load Washer?
Answer
Answer
The door does not lock and unlock thereby making it impossible for the washer to start when the... (More)
Answer
Failure of load door to lock and unlock therebay causing unit to not start when button is pushed
Answer
The fabric softener and bleach do not dispense during a cycle. They remain full after the load is... (More)
Answer
pls provide measurements for washer and dryer for maytag neptune tl
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Newport, KY
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
