burners are only lighting half way and then gas cuts out. Then the system repeats it' self. coleman heater mod #7995856, serial #1287658845. this is pretty close or just like heaters used in RV'S
OK, the burners will need to have flame on the entire surface or it will trigger a sensor and shut-off. Get a brush and maybe even one of thoes can of air and blow off the burner. Stay away from the glow ignitor because that is very delicate. Once you get flame on all surface of the burners, the unit should stay lit.
My Coleman furnaces with electronic ignition just stopped working I think its the ignition. how do I...
(More)
My Coleman furnaces with electronic ignition just stopped working I think its the ignition. how do I fix it?
hi, i have a el wagon and the centeral locking ,keeps going up and down, have not found a solution...
(More)
hi, i have a el wagon and the centeral locking ,keeps going up and down, have not found a solution as yet seems to happen when the car is out in the hot sun, in the shade its ok.
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble...
(More)
My Colman forced air heater is cycling acording to the thrmastat but wont heat up. The trouble shooting light flashes three times.What part do you think is failing?
evertime we lower thermostate at night then raise it in the morning the resit light is flashing then...
(More)
evertime we lower thermostate at night then raise it in the morning the resit light is flashing then we have to push button to resit furnace weshould noy have to do this help
i have a pro comp pc9001 distributor multi-spark box with a pc91 coil..my problem is where does the...
(More)
i have a pro comp pc9001 distributor multi-spark box with a pc91 coil..my problem is where does the distributor hook up to ..it has a black wire and a black wire with a thin yellow stripe .. which wire goes where .. what is the polarity of each wire
