Question about E-Machines eMachines Desktop PC
Speaker hookup? where do i do that?t
  • Anonymous Jan 20, 2009
    I plugged it into both green jacks and tried them both and the blue light is on but it still doesnt work it was just working the other day but i moved my computer and now i dont know how my boyfriend figured it out the first time
    Genius:
  • 1,601 Answers
There is a green jack that you plug your speakers into.
Posted on Dec 29, 2007
RCA & speaker hook up
I need code for : Blaupunkt GMBH 7 612 001 015, BNO 881. Made in Germany. Radio navigation AU Z1Z1B6079922
Thanks. my e-mail: max_zoki@hotmail.com
Best Regards.
Jul 15, 2013 | Car Audio & Video
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
I need to know how to wire this to my amp i have never wired a 3 way system and i need to know if i do any thing different
Typically on these units there is only one hookup for the amp or a left and right hookup. The crossovers are already inside the speaker box and will send the highs to the tweeters and the lows to the subs. Make sure that if you amp has an adjustable crossover that it is set to full so that all frequencies go to the speaker box.
Mar 11, 2011 | Kenwood KSC-7702 Car Speaker
I am very confused as to which connections to use for the speakers and subwoofer. Does the subwoofer and center speaker hook to the first ( left set of hookups as you are looking at the back) and the...
By the context of your question, this is for surround sound? If it is, then there should be a subwoofer slot or plug just for the sub. The left and right are for speakers only.
Dec 22, 2010 | Audio Players & Recorders
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
Only the center speaker hookup is producing any sound. When i hooked up my speakers to the front L and R as well as the rear L and R i get no sound, the only hookup that will produce any sound is the...
on the main board there is Amplifier its possible that its burned when you short or overload the speakers it could happend
let a technican check the Receiver
Aug 23, 2010 | Pioneer VSX-453 Receiver
How to hook up speakders?
The monitor does not have output sound since it is only an input device. You will have to hookup the speakers to your device (laptop, computer, gaming console) that you are connecting to the monitor. The speakers in the monitor are ready to receive a signal so that it can amplify it and let you hear it. If you hookup your speakers to the monitor it is the same as if you were trying to hookup two sets of speakers to each other.
If you need further help, reach me via phone at https://www.6ya.com/expert/hugo_f827544e52871d36
Nov 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Acer speaker hookup top laptops
I looked up the specs for your computer and cannot find a way to hookup external speakers. Short of upgrading to a soundcard that supports external speakers I cannot find a solution for you. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | Toshiba Portege S100-S1133 Notebook
Adcom GFA-5400 installation
Use the niles for more than one speaker hookup. As far as the sub hookup, use a powered sub with speaker inputs
then use the right or left speaker and tag a couple wires to the sub. Good Luck
BIGRED
Dec 28, 2007 | Adcom GFA-5400 2-Channel Amplifier
E-Machines eMachines Desktop PC Logo
41 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
