LG LS-L1210CL 12000 BTU Cooling Only Mini Split Air Conditioner
Problem for LG LS-L1210CL 12000 BTU Cooling Only Mini Split Air...
Need a manual for a LG split system
By me_again3 on Oct 19, 2009
need a manual for a LG split system
Solution #1
posted on Oct 28, 2009
Not Rated)
shastalaker7
Rank: Guru  Air Conditioners  Expert
Rating: 90%, 66 votes
You should be able to get a service manual from the manufacturer online and down load it? Or go to where this unit was purchased and they should be able to help you.Get the model, serial, and product numbers from both indoor and outdoor units to take with you. The more info you have the better. The outdoor serial number shows the manufacture date.Have you removed the excess panel on the outdoor unit to see if a manual may be inside? they sometimes put them there instead of handing them to the owner. Good Luck!
Sincerely, shastalaker7
Was this helpful?
Yes
No
Popular Solutions for LG LS-L1210CL 12000 BTU
Questions and Unsolved Problems for LG LS-L1210CL 12000 BTU
Do you recommend LG LS-L1210CL 12000 BTU Cooling Only Mini Split Air Conditioner?
Answer
Answer
My LG LSL121N-2 problems is stop working and indoor unit flashing five blinks.Please send me a fault... (More)
Answer
I have an LG room a/c Model # LWHD7000HR that cools for a while then the compressor clicks off and... (More)
Answer
i have two similar units (lg mni split same model), one works fine and the other no with the same... (More)
Answer
Dog destroyed the remote control unit. Need help on where to find it. Nelson
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG LS-L1210CL 12000 BTU...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
