Question about HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop
COMPAQ presario 5152
Computer screen states there is no system.ini
  • Longstreet7 Dec 29, 2007
    great site - thanks
It doesnt matter what system you have you fried *********** board or your hard drive
Posted on Apr 01, 2008
    Problem Solver:
  • 10 Answers
What version of windows are you using?
if you have windows 95 or 98 follow the instructions here:
http://www.computerhope.com/issues/ch000211.htm
Posted on Dec 29, 2007
How do I set a Compaq Presario SR1403WM back to Factory settings
Step 1:
While many problems with Compaq Presario computers can be solved by less drastic means, there are times when the best course of action is to set the computer back to its original factory default state. Issues with persistent viruses or spyware often require this drastic step, as do problems with a corrupt operating system. Learning how to restore your computer to its original state is an important troubleshooting tool.
Shut down your computer and restart it. Watch for the Compaq logo, then press the "F1" key to enter setup. Press the right arrow within setup to go to the Boot menu. Press the down arrow to access the "Boot Device Priority" option. Change the first boot device to CD-ROM by pressing the down arrow until "CD-ROM" is displayed. Eject the CD tray and place the recovery CD that came with your computer into the tray. If you do not have a recovery CD, you can order one directly from Hewlett Packard. Shut down and restart the computer. The Presario will automatically boot from the CD and begin the recovery process. Select the operating system your computer shipped with. Many Compaq recovery CDs support multiple operating systems, so be sure to choose the operating system your computer shipped with. Insert the operating system CD when prompted. Enter the license key for the operating system when prompted. The license key is typically found on a small tag located on the top or side of the computer.
Mar 10, 2013 | Computers & Internet
Compaq Presario SR1000 won't boot up completely :(
Hi Thanks for your question
I would suggest to enter "safe mode" and then do system restore again. To do this you need to follow these steps.
1.Turn your PC on and press F8 on start up. This should take you to the screen asking what you want to do. 2. Choose safe mode from the list and press enter. 3. Once safe mode loads you should be asked if you want to restore your system to previous state. Just press no to run system restore and follow steps (you already know how to do this)
Shutting your computer down without closing operation system properly may cause start up issues like this one.
I hope this helps you. Good luck
May 26, 2010 | Compaq Presario SR1000T (568657) PC...
"<Winnt_root>\System32\Hal.dll missing or corrupt:
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Windows will not start
This looks like a Windows failure due to a new installed software or system tweak, or anything to do with Windows actually.You can try pressing "F8" button while your computer is booting (a couple of times since the windows dos select menu appears), then you can try to open the windows in the "Safe Mode", and when you get there, you can try to restore your system back in time a couple of days, to a well-working state. (By using system restore option)
Apr 14, 2009 | Compaq Presario SR1000T (568657) PC...
My Compaq Presario notebook won't start up
Hi there
at boot, hit F8 and then select "last known good configuration"
/Teis
Jan 15, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 12, 2008 | Compaq Presario 1700 Notebook
Invalid boot.ini
One of these two methods should fix your problem......... -------------------------- go to run and type in MSCONFIG. Then click on the "Boot.ini" tab. First, make sure if using XP Pro that the following is listed: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect - this is the boot.ini information from XP, straight from the Microsoft Web Site. All the information below [operating systems] should be on one line! If you have a blank boot.ini file, copy and paste this information - if all information is already there, then don't change anything. Next, click the button that says "check all boot paths". You should get back a message stating that everything is good (the computer checks to make sure the boot.ini file is compatible with Microsoft Operating Systems). Next, assuming your computer likes the boot.ini file that is in there (and it should), then click the button that says "set as default". By doing this, you have now created a new (modified) boot.ini file that is a carbon copy of the original. Click apply. You will be prompted to restart. Before doing so, go back to MSCONFIG and in the general tab you will see that "use modified boot.ini" should now be checked. During reboot, you should not get the invalid boot.ini message (at least I didn't). What you will get is a message (after reachign the desktop) stating that you are not using the defaults or something like that and do you wish to go back into MSCONFIG to restore the default settings. Since your new boot.ini file is exactly the same as your original, click no and check the box to hide that irritating message. ------------------------ Or you can try this method.... right click on my computer go to properties then click the advanced tab then cilck settings under start up and recovery under system startup then click edit and paste [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect --------------------------------- Peter
Oct 04, 2007 | Intel Motherboard
Slow moving computer
Yes, If you have no problem losing your data. If you care about your data I would install a good antivirus program if you are not using one . If you are using one make sure it is updated and perform a full system scan. Also if you have the newst version of Internet Explorer clear out your temporary internet files & cookies.
Sep 24, 2007 | Compaq Presario 5005 (470014-507) PC...
HP Compaq Presario SR1420nx (SR1420NXPS69AA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
