Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the menu the panel (screen ) is bad.
The cost of a new panel is probably more than a new Tv.
Try reseating the ribbon cables before trashing the TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
when turning on the power on the tv the green light comes on and about 2 seconds later it shuts off,...
(More)
when turning on the power on the tv the green light comes on and about 2 seconds later it shuts off, eventually after about 20 tries. it will turn on
I have a 42 inch. plasma pioneer tv approxamately 3 years old and the audio is not working, with the...
(More)
I have a 42 inch. plasma pioneer tv approxamately 3 years old and the audio is not working, with the souround sound system. It is pioneer also approximately 10 years old, everthing is pluged in properly, the sound just went out when I turned on the system. I think it is probably the reciever on the sound system, and I am willing to replace it if need be , I just want to make sure it is not the T.V. system input. The cd and a.m./f.m. sound works with the reciever just not the audio for the t.v. perhaps it is the cable, however I tried a different audio cable and it did not work either.
I have a Westinghouse W-32701 26" plasma TV which just developed a thin horizontal line across...
(More)
I have a Westinghouse W-32701 26" plasma TV which just developed a thin horizontal line across the middle of the screen. It started on the right side and over the past couple of days it has progressed slowly across the screen and is now almost to the left side. It looks as though the line to the right side may be getting thicker and darker.
