Master
- Posted on Oct 19, 2009
Re: My LCD has hizontal lines appearing. But if I press...
Warning: the LCD screen can be easily damaged if you
open it up. If you do something wrong the screen might become
completely unusable and you’ll have to buy a new screen. It’s very
expensive. Think twice before you decide opening the screen. Continue
at your own risk.
- First of all remove the battery from the notebook.
- Lift up rubber screw seals and remove all screws.
- Carefully separate the screen bezel from the LCD cover and remove the bezel.
- Remove the screws from the front and from both sides.
- Carefully remove the LCD screen from the cover and place it on the
notebook base. Disconnect the video cable and the inverter board cable.
- Disconnect the screen cable and remove the inverter board by removing both screws holding it.
- Clean the terminals then reattach the cables firmly.
