RCA HD52W59 Pincussion Problem
I'm visiting the kids in remote Arizona. They have a Big Screen RCA model HD52W59 with a Pincussion Problem. It comes on within a normal warm up time with the problem big as day..... top and bottom and convergence out of wack. Is there anything I can look for...... or a board that I could take back to the Big City for repair???
Thanks
Grandpa (old TV repairman)
  • 1 more comment
  • GR8 Normondo Dec 29, 2007
    It is a ITC222A chassis.
    The picture comes on with R G & B lines concave across the top and then at full on, the picture is concave at the top and convex at the bottom.
    Thanks for the quick response.
  • GR8 Normondo Dec 30, 2007
    Ok....as I understand, I don't have the auto convergence option in the setup menu. That means I should check fl231. If this fuse was OK, does that place the auto convergence option back into the setup menu?
    Thank you for your help. I will try this tomorrow......with care.
    Genius:
  • 1,153 Answers
Is this chassis a ITC222 ? If so then, yes there are things you can look for.
Posted on Dec 29, 2007
  • Lashawn Robinson Dec 30, 2007
    Sorry been kind of busy, I saw other mention FL231 which can be correct, but along with this I would change also DL231 and other things to check is connector BW005 to see if bowed, and also RP610 to see if open. This is a 220K ohm resistor. Try this and you should be ok, now if no luck you may need further info, you can try ctechnicians.com
    Guru:
  • 1,894 Answers
Take a look at these pics and let me know is this the problem like
http://i49.photobucket.com/albums/f28...
  • 4 more comments
  • dewan nafees ahmed Dec 29, 2007
    It appears to have a pincushion issue too as both the left and right sides arch upwards.
    try the service menu pin chusion settings.
    I think it has the issue with the convergence IC chips if the auto-adjustand service menu manual adjustment make no difference in the convergence of the picture.
    The shape your seeduring this problem is called 'V Bow' and 'Pincushion' which needs to be calibrated again.
    Theres probably a diode that went out. The tech can open it up and
    adjust the angles back. I wouldn't charge over $100-$150. Shop around
    for a good repair tech.
    if its pincushion issue or convergence.. please be clear..
    pincushion will not cost you more than 200$ for sure (if u r loacted within 40km from service person).
    http://techlore.com/forum/thread/18493/S...
    for convergence issue read this forum for more info...
    to do convergence manually
    To adjust the convergence on your model TV:
    1. Access the main menu
    2. Arrow to SCREEN and press OK
    3. Arrow to ADJUST PROJECTION TV and press OK
    this s a convergence issue i think.. but i dono why that lines are coming..
    auto convergences option was also
    gone means. The small fuse labeled fl231 which is right next to the big
    plastic piece with the large red wire coming from it in the left corner
    of the circuit board closest to the back. It is the middle
    of the 3 small fuses that are smaller than a Chiclets gum.u will be
    able to pull up the circuit board and jump the fuse with some alligator
    clips and the set will look great again.
  • dewan nafees ahmed Dec 30, 2007
    ya correct. that is what to be done.
    but do with care.
    handle safely. in even of correcting this problem dont mess up other things.
Why is the picture is to high or big and cuts off the heads of the people on my RCA HD52W59 rear projection HGTV
its setting the screen format . take the factory remote and by using the cursor left or right you can scan the size changes
May 23, 2014 | RCA HD52W56 52" Rear Projection HDTV
RCA big screen turns off then back on.
I cant get my comcast universal remote to program for my rca hd tv
Nov 27, 2010 | RCA HD52W59 HDTV Projection Television
My big screen won't turn on, but it's plugged in
That model is famous for having capacitor issue and bad flybacks both items are all on the deflection board. You can get replacement deflection boards for the RCA ITC222A TV( which is what your model is) from www.tvrepairworld.com they also include instructions how to remove the old board.
May 25, 2010 | RCA HD52W59 HDTV Projection Television
Picture to big for television screen
Look for a button on the remote that reads Pic size, aspect or zoom. Press that button repeatedly until the desired picture size is achieved.
Nov 01, 2009 | RCA HD52W59 HDTV Projection Television
The picture is to big for the screen and looks like it has a u shape to it
the pincussion circuit is likely the problem a capacitor in this circuit is usually at fault - the part would have to be rplaced.
Sep 13, 2009 | RCA P52960 52" Rear Projection Television
Picture too big for screen
on your remote push the arrow key to the right or left side. this should change format and go into customer setup and turn of autoformat
Aug 31, 2008 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
