Canon PowerShot A620 Digital Camera
Problem for Canon PowerShot A620 Digital Camera
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
By sandys111 on Oct 19, 2009
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB memory cards for camera - multiple times, all with no results.
* 2 GB - was able to use for 3 (three) days and take 3 (three) pictures before "Card Locked!" message
* 4 GB - "Card Locked!" message on screen from debut
Looked inside camera - switch is not "stuck" in open position.
Now what? Time to buy a new camera?
Very frustrated.
Best Solution
posted on Oct 19, 2009
Very Helpful)
t00nz
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 91%, 2006 votes
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Comments:
Oct 19, 2009
- Oh and if the 2GB card was already in the "unlocked" position, try formatting it in your camera. Press the Menu button, and select the "tools" menu. Scroll down to the selection stating your card's memory capacity and select it. Then follow the on-screen prompts to format it. Note that this will also totally erase the card, so download any important pictures first before doing this.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Canon PowerShot A620 Digital
Questions and Unsolved Problems for Canon PowerShot A620 Digital
Do you recommend Canon PowerShot A620 Digital Camera?
Answer
Answer
is it possible that the 2gb lexar is not compatible with the powershot A400?
Answer
My camera has a white speck of dirt underneath the first lens, and does interfere in pictures and... (More)
Answer
camera used in light rain, flash banged and quit, works otherwise is it possible to fix myself with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot A620 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
