Question about Edimax BR-6104KP Router (BR6104KP)
Print server problem
I can't get the printserver to work whita a canon pixma mp 130, after installing the print server client, no ports are added.
  • zrlaszlo Jun 24, 2008
    Tried to connect a Brother HL-1250 to the Edimax BR-6104KP Router and not even the leds are lit. If you have any answers, please email to zrlaszlo@gmail.com.
    Thank you a lot!
I sorry but I am the similary problem whit my edimax equimed , what i can do , im dont print whit it.
Posted on Feb 07, 2008
My canon mp 130 printer will not print color i
Check to see that the "Greyscale" tab hasn't been set, and it is set for color printing this is in printer properties.
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
MP830 and JetDirect 175x print server
hmm ok you got windows xp right
]now here is what you do
CLICK START / PRINTER AND FAXES
SELECT ADD A PRINTER
THEN SELECT A NETWORK PRINTER AND CLICK NEXT
SELECT BROWSE FOR A PRINTER AND CLICK NEXT
SELECT THE PRINTER AND CLICK NEXT
NB.. It may require your printer driver so keep it handy and only insert the disc if it ask you too..
OR YOU CAN TRY
CLICK Start \ My computer \ My Network Places
Click View Work Group Computers
Double Click On Your print server
Double Click On Your Printer To install it
OR IF YOUR PRINTER DOES NOT SHOW UP
Doublew Click On Printers and Faxes, Right Click Your Printer And choose install
Again Just incase keep your driver handy..
NB on some printservers you may need to right click your printer and choose install..
IF YOUR PRINTSERVER DOES NOT SHOW UP IN MY NETWORK PLACES YOU GOT IT SET UP WRONG...
Jan 17, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printers are not recognized as online by printserver
Have you check which port your PC trying to register your printer to?
Sep 22, 2007 | D-Link DPR1260 Rangebooster G...
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
I want to know if I can print without USB using my wireless, I have a Canon pixma mp160.
Canon Pixma MP 160 do not support Wireless Interface
So you will need to connect it to USB port in order to print the documents
Interface
USB 2.0 Hi-Speed3
Direct Print Port
Specifications for Canon MP 160
You can refer the Canon MP 160 Manual for further inofrmation
I hope the above resolves your query
all the best
Do rate the Solution, as we can guide others accordingly
Thanks in advance
Jan 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Pixma ip 5200 r -> CD Labeler Problem
After long research .... I found out that the pixma is indeed a network printer ;) .... BUT it has a printserver already build in!!!! Having 2 Servers is obviously not too good of an idea ;) ....still wonders me as to why it did work in the 1st place ..... (i guess there was something wrong with the w2k3 print server *muhaahha)
May 07, 2008 | Canon PIXMA iP5200R InkJet Photo Printer
PSUS4 problem "talking" to Canon S330
Hi dreaddymck
I need a little more information on the setup. Is there a router in your network? If there is, is your PrintServer connected to the router and your computer is attempting to connect to the printserver through the router? If there is no router and your PrintServer is connected to your printer via the USB port and your computer is connected to one of the ports on the PrintServer via a cat5 cable, I would check to see whether you are actually communicating with the PrinterServer by pinging its IP address from the computer. If the ping is successful, then I would look at the printer properties in your computer's printer control panel and check the port configuration. Usually it is shows the IP address, port 9100 and port protocol is usually set to RAW. Otherwise I would attempt to reinstall the PrintServer using the CD originally provided. It appears to me that the server may not be publishing its IP address on your network.
--RoadHawk
Nov 27, 2007 | Linksys PrintServer for USB with 4 port...
Print server
Hi I have found a link below that will assist ya to set it up all right... http://tech.yahoo.com/gd/adding-a-wireless-print- server-to-your-network/200458 Ya must ensure ya have the drivers on ALL the "Client" computers... IE: install ya "Drivers" on each PC...
Sep 18, 2007 | Linksys Wireless-G WRT54G Router
Printer Offline
If your problem still persists then If the printer and the printserver is on and connected to the printserver and the router respectively. Then try right clicking on the printer icon in the printers and faxes window to set it online. Try Printing. If it did not work, then right click on the printer icon again > Properties > Ports > set the proper network port. Apply the settings and try Printing.
Sep 27, 2006 | Lexmark N4000e Print Server
Edimax BR-6104KP Router (BR6104KP) Logo
245 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Michael Galve
Michael Galve
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
