Polaroid DVG-1080P HD Camcorder Logo
Posted on Oct 19, 2009
My Camcorder is taking a long time to format my sd card. It still isn't formatted. It's been about 30 minutes. Is there something I'm not doing right?
actorboy38
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Sep 06, 2010
actorboy38
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
16978
Points
36
You should try formatting another card. If it formats the other card fine, then something is wrong with the card you were trying to format first...
Need help working my camcorder/camera
In order to record, the camera needs to have a memory card installed. This particular camera needs an SD format card. If the camera does not have a card installed, the card is not properly formatted, or the card is full, you will not be able to record. Also, these cards have a write protect lock tab. Make sure that the tab is not in the lock position. The card should be formatted FAT32. If you can read the card on your computer, make sure it is not full and that the card is formatted FAT32. If you have another camcorder or camera that uses SD cards, you might want to try formatting the card, just to be sure.
When i insert sd card it say not supported card
Try formatting the SD card using your computer. Insert the SD card in your computer. Open My Computer, find your SD card drive, right click on it and select Format. Choose FAT for the filesystem and continue with the format. When the format is complete, insert the card into your DVD Camcorder and try again.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2helpful
When i try to format the SDHC 8GB memory card the recording screen display's (Waiting....) for about 1 to 2 second's, then goe's to the normal recording screen and when i push the record button it...
Hi, look here's what to do, get yourself, or access to, A Computer, and a USB SD card reader, now, insert your 8GB SD card into the reader/writer, It will show up as a HDD in My Computer, and then, Format it FAT32. Now return it to the Camcorder, when turned on again, the Camera NOW should "See" the SD card. You may even be asked if you wish to Format,again,say YES, and do so, if NOT asked that;s OK too. as, you should now be able to, in either case, be able to have access to the SD card, and can change your phone settings accordingly, the extra storage will simply be "Picked Up" by the Camcorders software.
If this doesn't happen, then there maybe a problem with THAT SD card or the Camcorder? try another SD card before thinking the camcorder has a problem though.
1helpful
My polaroid dvf 130 camcorder won't connect to my computer.the software it came with says it doesnt need a driver since I have windows xp what should I do?
this is what i did, and it worked perfectly. go out and get a sd card * any gig u want* as soon as u put the sd card into the camera, FORMAT IT!!!!. do that before u do anything else. don't format it on ur pc or laptop. format it on the camera. if u do that it will work perfectly. i don't know why it wasn't in the manual to format sd card first. but if u try to take pics first, that will mess up the entire system and u will be assed out a sd card. it took me 3 sd cards to figure this out. the cards worked fine but not in the camera. then i formatted it on the camera first and it works fine. the other sd cards i use for other things, i won't discard them but they won't work in the cam. but remember again GET NEW SD CARD AND FORMAT THE CARD IN THE CAMERA FIRST.
2helpful
2answers
When I turn on my Jazz DV 152/ T20 it displays "Read card..." and then nothing happens...I have a 4GB SDHC card by SanDisk...both camera and card are new....is this a faulty camera or am I doing something...
Usually the first thing you need to do with any SD card and Camera is to go into the settings of the your camera and Format the SD card. This has to be done for each memory card you use with that camera. i.e. a SD card formatted on a Panasonic HD camcorder won't work in your Jazz Camcorder. The formatting is different between the two camcorders. New SD cards don't come formatted.
SO try inserting the SD card into your Jazz Cam and rummage through the setting until you find your memory settings. From there find the Format Memory Card function, format the SD Card and you should be good to go.
How to format a SD memory card for samsung
Hi Sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • 0helpful
    2answers
    Is the vivitar dvr 530 compatible with sdhc cards
    Plug the SD card with contact terminals facing away from battery. It most likely is using internal memory which is much smaller. All cards under 4gb are normal SD. The camera should be able to format the card, or use an adapter and windows will format (default settings).
    3helpful
    4answers
    Xacti VPC-HD1000 "Problem with SD card" "FORMAT / FULL FORMAT"
    This card is not compatible with your camera try another brand!
    This should fix ya! ( ( all sd cards may look alike but they are not!)
    2helpful
    3answers
    SD card
    you can try some data recovery software. You can see
    recover files from sd card
    It tells the steps how to perform data recovery.
    If above does not work, you may have to format the memory card (use quick format), and then use sd card recovery software to scan again the memory card and recover your files.
    1helpful
    Error 30
    The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
    Top Polaroid Video Cameras Experts
    Tony Parsons
    Tony Parsons
    ADMIN Andrew
    ADMIN Andrew
    Are you a Polaroid Video Camera Expert? Answer questions, earn points and help others
