Sub-Zero 611 / O Bottom Freezer Refrigerator
Problem for Sub-Zero 611 / O Bottom Freezer Refrigerator
My Subzero Condenser fan runs constantly - but coils are clean
By tombns544 on Oct 19, 2009
My Subzero Condenser fan runs constantly and the vacuum condenser light flashes- the coils where vacuumed , air blown and tested for cleanliness - IT IS Clean - I am assuming it is a sensor that is bad or dirty. The frig and freezer are perfect no cooling problems at all. Whay is the problem? PS The compressor does turn on and off as normal.
Comments:
Nov 21, 2009
- Thanks for the reply, Dan. It is very ironic that I finally got a chance to fix my Sub Zero just now before I saw this reply. I guess my question need more detail, I figured the problem out myself by reading info all over the web. It was low on R-134a!!!!!! Bought the house in Jan 2005 with the frig in place and the vaccum condenser light was flashing since than. So I thought is was normal- indication a Vaccum seal condensing the air in the frig.. Go figure. any way.. Realized it was not normal after reading manual so I 1.Vaccummed the condenser coils. 2. Noticed that on the evaporator coils there was a bit of frost near the inlet. ( indicating a low charge) 3. Saw someones post stating that the Sub zero light flashes when the compressor is running longer than it should. 4. Noticed that the condensor coil unit had a date stamp of 2004 but the frig was made in 1999. So some work must have been done on the unit right before we bought the house. So I figure the charge was low based on this info and assuming the person who did the work did not charge the unit properly. I purchased a manifold gauge and sure enough the PSI was at zero while running when I should be between 5-10 psi , charged it a bit and now it is fine. The condensor fan shuts off when it should. I could not find info on the web easily since there were so may factors effecting the unit. Hope this helps someone else. Found the procedure on You tube, and only cost me $60 total with R134a and all. I used a treaded can tap with an adaptor I purchased at home depot to attached the the A/C manifold gauge. 1/4 male flare to 1/4 female Brass pipe.
Solution #1
posted on Nov 21, 2009
Not Rated)
Daniel Blum
Rank: Apprentice
Rating: 0%, 0 votes
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Was this helpful?
Yes
No
Popular Solutions for Sub-Zero 611 / O Bottom
Questions and Unsolved Problems for Sub-Zero 611 / O Bottom
Do you recommend Sub-Zero 611 / O Bottom Freezer Refrigerator?
Answer
Answer
The upper tray of my 611 freezer is stuck closed. I cannot pull it out. When I try, it comes out... (More)
Answer
I hear the fan is on all the time in my Subzero unit. Is this normal?
Answer
Sub-Zero 611: The control panel and light in the refrigerator are not working. The compressor is... (More)
Answer
part that controls the medal arm that drops down to make ice and retacks to stop on model 611
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
