Question about Linksys Wireless-G Game Adapter [ WGA54G ] (108451)
HELP PLZ setting up o a 2wire router with gaming adapter
I'm having trouble connecting my wireless gaming adapter to my 2wire router.
i used the set up cd and i connected the wireless gaming adapter to my 2wire router with an Ethernet cable and set it up to my router.
set up my ssid
then auto set up the ip address
and typed in my WEP key
after that it starts to config.
then its done and all 3 lights are on on the gaming adapter. power, ethernet, and wireless.
i disconnect it from my router and take it up stairs to my room and connect it to my ps2 and it run the game but it wont connect at all. all y lights are still on but it wont work.
i set it up to my friends next door linksys router and it works great. but his router is down and i cant connect.
can any please help me connect it to my own router.
thank you
  • shawn707 Dec 29, 2007
    no its in range because my psp, and laptop can connect to it fine with more then 90% connection. it jst dnt let me connect it to my sp2, the lights are all on. and i reset it like 20 times. it just dont work. it worked when i connected it to my friends linksys perfect
    Problem Solver:
  • 10 Answers
Could it be possible that the game adapter is out of range of your router?
Posted on Dec 29, 2007
  • Jason Behfar Dec 30, 2007
    I'm sorry the only other thing I can think of is that it's using a different wireless frequency, like if your network was wireless b/g and your gaming adapter is wireless N.
    Have you checked for any software updates from the manufacturer?
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
New wireless adapter will not get IP address
plz i want to dsl wireless connection plz call then now +92332330458
May 03, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
first of all let's start from the complete facts, does your 2wire router have built in wireless or no? how you did the the cable connections between tht routers?.
Apr 04, 2009 | 2wire HomePortal® 1800HW Router...
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Linksys Adapter and 2wire router
  1. ensure that a wireless connection is created in control panel on the pc, it may not even be attempting to connect
  2. ensure that the router wireless is turned ON, it may have been turned off as a security measure when no wireless pcs were used
  3. The security settings on the adaptor may be set to the office network and locked
    wep password at home is different or not enabled, so the secured adaptor will not connect.
make any changes from a cable connected pc (no chance of data loss)
access the routers settings page and check the settings,
then ensure the adaptor rom if present is set to the same settings
Jul 16, 2008 | 2wire 2700HG-B Router (2700HGB)
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Apr 11, 2008 | 2wire (1000-400108-001) Router
Gamin adapter set up, plz help
Hi Shawn. Does yout PS2 connect when it is downstairs on the wireless? Reason I ask is wifi routers tend to transmit horizontally, and are very weak in vertical transmittions.
If you are connecting while you are own stairs, we can assume the WEP is not an issue.
WEP setting vary on different adapters. Some allow your to use 5 digits for your wep code, others require the full 10 digits. If you are using just 5, say 12345, try putting a 3 infront of each digit, i.e. 3132333435. If you are using all 10, on bought the adapters, this shouldn't be a issue.
Of course, if you can connect to while downstaris, this issue it mute.
You can also try changing channels. Channel 1 has more range than channel 8.
The last guess is that yoour router has less range than the Dlink.
See if any of those suggestions help, and let us know.
Good luck.
Dec 29, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
Hooking up my gaming router
There is a 90 % possibility that the wireless settings on the gaming adapter and the router are not the same. Try to reconfigure this again. Remember that the gaming adapter's wireless settings needs to synchronize with that of the router to make the gaming adpater works. Call netgear and verify the settings on your wireless connection and reverify the settings you have on the adapter. For manual instructions, see user guide at www.linksys.com/download
Oct 15, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
2wire router and usb adapter
first u need to connect a pc through wired on the w/l router and go to w/l part and configuge it
Oct 05, 2007 | 2wire (1000-400108-001) Router
Linksys Wireless-G Game Adapter [ WGA54G ] (108451) Logo
269 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
