Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Problem for Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with...
Display says hi temperature, wont change when i
By focheesy on Oct 19, 2009
Display says hi temperature, wont change when i adjust it. Tried turning it off/on and putting it on factory defaults. Also, air filter change light is on, and water wasn't coming out for a while until i just reset it. Any tips?
Solution #1
posted on Oct 19, 2009
Not Rated)
jadamsrrfcu
Rank: Guru  Refrigerators  Expert
Rating: 90%, 133 votes
Check underneath the refrigerator to see if the coils are clean. If they are covered with gunk, clean them.
Next, check the operation of the compressor (close to the coils mentioned above) and the compressor fan (also near the coils toward the rear of the refrigerator). Both of these must run for the unit to have the proper level of cooling. If the compressor fan is not turning, you will need to replace the fan motor.
Another possibility would be an inoperative evaporator fan inside the freezer unit. However, when this fails, the freezer often remains adequately cold at the top. The refrigerator part does not get cold enough.
Was this helpful?
Yes
No
Popular Solutions for Electrolux 25.9 Cu. Ft.
Questions and Unsolved Problems for Electrolux 25.9 Cu. Ft.
Do you recommend Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel?
Answer
Answer
The seal has gone on my freezer door...do i need a new freezer completly or just the seal?
Answer
I have a Electrolux Side By Side fridge model EI23CS55GS1. This is a model with the non adjustable... (More)
Answer
my ice and water dispenser will not shut off when we remove our cups from the dispenser. How can we... (More)
Answer
lightning strike/power surge has caused my refrigerator compressor to stop working. it is getting... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Electrolux 25.9 Cu. Ft....:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
