Question about Maytag Neptune MDE5500AY Electric Dryer
Mde9306aya How do I take the front off
Everything I have looke dup says there are screws but my dryer does not have any screws holding the front on. I need to open it to clean out the blower and can't figure it out
  • 36 Answers
Open the top and look inside on the left and right sides of the front panel some maytags have two screws on the front panel just below the door where the hump is if thats your mod take those out and pull the panel out at the bottom then down as there are two spring clips at the top if thats not your mod then take a putty knife facing the drier come from the edge about two inches then depress the spring clips one at a time and lift the top but i think blower wheel is under the back panel
Posted on Dec 29, 2007
Trying to take cabinet off my MAYTAG MCG8000AWW dryer. Need to replace the motor pulley. It broke off.
And you can't find that first screw that undoes the whole thing? I am not familiar with this unit, but have found that most dryers magically open the same way. If you open the dryer door and look around where the dryer door seats, you "may" find 2 screws that hold the top down. Take those screws out and the top will lift up and then you need to look inside the front panel to find a couple of other screws which hold the whole can of worms together. Be aware, once you loosen the front panel, the drum rides on that panel so you need to support the drum when you remove that panel. Hope this helps
Oct 18, 2013 | Maytag Neptune MCG8000AW Gas Dryer
I cant figure out how to change the light bulb on my Bosch WTL 5410 Condensation dryer. The bulb cover is at 12:00 inside the front cover (hard to crane your head around to see up there). I can't feel or...
You need to go through the top panel with the switches to access the bulb. First remove the screws that hold the top to the dryer. (There are a series of tabs with the screws.) Next, use a flat blade screw driver to push down and pull out the plastic tabs along top of the front panel. Pull the top of the front panel back. Now look for some plastic tubes. Stick a screw driver down into the machine and pry the tubes up at the bottom. Then you can access the light bulb and its socket.
I hope this helps.
Oct 01, 2017 | Bosch Nexxt WTMC 3300 Electric Dryer
Ok, I have an LG Dryer, model # DLE 0442w. It is making a horrible vibrating noise. I believe it has something to do with the venting system. I have tried just about everything to get the front of my dryer...
Use a flat screwdriver and place it in the gap between the front panel and the top panel about 4" from the sides. Push in to unlock the clip holding the top panel to the front panel. There is one on each side. Lift the top up and remove the 2 screws holding the front panel on top. Now open the door and remove the 2 screws holding the front panel to the filter screen insert. Pull the whole panel out and disconnect the wire connection to the door switch. Lift the entire front panel up and out and you will have access to the blower wheel on the bottom left.
Good luck.
Jul 11, 2011 | LG DLE0442 Electric Dryer
My dryer will run but not heat. Was looking for the element but dont know how to get to it. Can you help
depending how old it is, some have a small door down at the bottom in the front. Others, you have to take the front off the dryer and you will be able to get to everything. Unplug it first before you try this. There may be at least 4-6 screws holding the front panel on.
Apr 08, 2011 | Dryers
How do I replace the heating element?
This dryer is easy peasy to repair. Only 2 screws hold the element onto its mount. The limit and thermal fuse are also mounted on it. The control thermostat is mounted on the blower housing. Everything is accessed from the front. themobilian_635.jpgthemobilian_636.jpgGet the front panel off by removing a few screws once you have raised that top. Then you can easily access that heater elementthemobilian_637.jpgthemobilian_638.jpgI looked up your model number and this dryer is an Amana type dryer
Here is your manual
Dec 31, 2010 | Maytag MDE308DAYW Electric Dryer
I have a Maytag Dependable Care Plus/Heavy Duty dryer (LDE8704ACE) that has served me well with no problems for more than 16 years. Yesterday, it started making a thumping noise that sounded like a huge...
hi look at the lower bottom of front there are 2 screws pull from bottom hing out watch for door switch wires swing front around. look in side top left and right corners 2 5/16 or 3/8 bolts pull them out. lift top up you will see screws that hold fin. oh turn power off hope this helps jim
Oct 13, 2010 | Maytag PYE2300AY Electric Dryer
Tumbler belt came off
  • Unplug your dryer from the electrical outlet. Remove the lint trap by lifting its cover and sliding it out. Use a screwdriver to unscrew the two screws that hold in the housing of the lint trap.Lift up the top panel of the dryer and take off the holder for the door switch wire. Look for the screws that hold in the front panel of the dryer, located on top of the front panel, and unscrew them. Take the panel off the dryer by lifting it off.Look inside the dryer, find the broken dryer belt, and before taking it off, note the way it is routed around the pulleys, then take it off. Install a new Whirlpool dryer belt by slipping it around the tumbler with the grooves facing the surface of the tumbler. Ask an assistant to hold up the tumbler while you move the belt into the proper place, aligned with the black line around the width of the tumbler.Wrap the new dryer belt around the pulleys as noted in Step 3. If you don't remember how, or the old belt was snapped and not aligned properly, look at the dryer belt diagram in your user's manual.Align the front panel of the dryer with the tumbler. Put back in the two screws that hold the panel in place. Open the door of your dryer and with your hand, turn the spinner one time counterclockwise. Reconnect the holder for the door switch wire, being careful that it doesn't touch any moving parts.Use the screwdriver to carefully position the rubber seal along the back of the tumbler. Make sure the seal is on the outside of the tumbler and that none of it sticks to the inside of the tumbler.Slide the lint filter and housing back into place, and screw in the two screws that hold it in. Plug the cord of the dryer back into the electrical outlet and check that it spins properly.
  • Oct 11, 2010 | Whirlpool Dryers
    How to disassemble a GE DBXR453EV0WW dryer?
    Unplug the dryer.
    Remove the screws from the control panel top rear.
    Lift the control panel aside.
    Pull the top lid forward to remove it.
    Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
    Remove the door switch wires and set the front panel aside.
    Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
    Jan 03, 2010 | GE Dryers
    My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
    To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
    Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
    Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
    Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
    Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
    Replace door switch wires.
    Lift the top and make sure the belt is positioned on the drum where the old belt was.
    Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
    Reinstall the rear door with all the screws.
    Faster the top down and plug the dryer in and test.
    Your done.
    Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
    Drum noise
    Ordered drum from Sears parts. 3045EL1002D
    Cost of 85$ + 15 to ship. It came in 5 days.
    Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
    driver. Take your time and look over the situation. I hope that I rememberd
    everything. Good luck.
    Dryer Drum Repair
    Dryer Drum Repair
    1. Remove L bracket with 6 screws at the top, rear.
    2. Slide top back 2 inches to unlatch and remove.
    3. Remove control panel with 2 screws at top, inside corners.
    4. Carefully unplug 4 plugs from back of control panel.
    5. Looking at inside at the top. Remove wiring bundle from 2 guides.
    6. Unplug wire from dryer light.
    7. Open dryer door and unscrew 2 screws behind door just below lint trap.
    8. Remove 4 screws at top of front panel that holds the door.
    9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
    so I carefully rotated it an set it on top of the dryer.
    10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
    11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
    12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
    13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
    sides. Lift drum to free from rollers.
    14. Observe how drive belt is routed around motor and tension roller. Push tension
    roller up and release belt. Carefully take belt off and remove.
    15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
    16. While your're there vacuume up dust and reverse procedure to install.
    Aug 13, 2008 | LG DLE2514 Electric Dryer
    Maytag Neptune MDE5500AY Electric Dryer Logo
    81 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
