Question about Philips 46PP9302 46" Rear Projection Television
Magnavox 48" alignment
Replaced fluid in blue and green, but cant seem to get alignment correct. Whats the trick?
  • jajr Feb 23, 2008
    bowing green and red on screen. Repairman came in said it was a convergence circuit. Wanted to charge me $700.00 is that to much?
    Genius:
  • 1,153 Answers
How bad is it? Yes convergence can be a job. Remember green is stationary and blue and green is what you use to line up on green. More info ctechnicians.com
Posted on Dec 29, 2007
Sony KP-57WS5610 Blue light will not converge the blue is offset from everything else on the screen so its like a blue shadow Any ideas on whats wrong
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit fromTvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 20, 2012 | Sony KP-57HW40 57" Rear Projection...
Lack of cool tones,seems to have pink tint where itshould be white? just got this tv from a friend today,trying to figure out best way to correct picture
Check the CRT fluid in the blue and green CRTs. It should be clear. These sets have problems with the fluid getting cloudy and hence letting less light through. It also gives it a dull picture look. If the fluid is cloudy, you will have to remove the CRT and replace the fluid. Then re-align the CRT via the convergence in the service menu.
Feb 19, 2011 | Philips 50P8341 50" Rear Projection...
My picture is O.K., but the colors are not right. Too much green. I can't seem to find an adjustment that corrects the problem.
TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 27, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My screen is discolored and blurry. Please advise..
Sounds like contaminated fluid. Each of the 3 crt's in your set have coolant to keep them cool. This coolant over time gets contaminated and causes extreme blurry picture. ITs extremely common on the Magnavoxs. Its also a pretty big job. Replacing the fluid isnt too difficult but because the tubes have to be removed it means both physical alignment and electronic alignment will be necessary. Also dont remove the green tube until you have done both the blue and red and aligned them to the green. Then do the green.. I hated doing that job lol.. I dont recommend you trying it and probably wouldnt be cost effective to pay a shop to do it either.. I recommend buying a new set... Sorry
Oct 19, 2010 | Philips Magnavox 9P6034C 60" Rear...
Colors dont align
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Jvc av-48wp74 48 in widescreen green projector problem
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 27, 2009 | JVC AV-48WP74 48" Rear Projection...
I have a 8P4834C 48in. rear projection tv and it had a green tint to it now it seems cloudy what gives
Your fluid in the CRT's ( mainly Blue & Green ) needs replaced. Not something you should attempt if you've never done it. A service company normally charges $250 - $350 for the whole job. The fluid is called Ethelyn Glycol, or antifreeze as we call it.
Jun 07, 2009 | Philips 8P4834C 48 in. Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
I am preparing to chang the fluid on a Magnavox FP4650 W102 Projection Screen Television. The blue and green have mold and the red is clean. I am looking for a manual on the correct procedure to change the...
Be sure to change the seals & coolant...have parts in hand before dis-assembly...you will need the service manual for
your chassis / model...google search ......................T.
Feb 08, 2008 | Televison & Video
Philips 46PP9302 46" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
