Question about Yamaha RX-Z9 Receiver
Zone 2 problem
I have had an ongoing problem with my Z9 shutting off intermittently. I suspect it has to do with zone 2 running in background. I have limited the power to zone 2 by adding manaul volume switches for the zone two speakers and a speaker selector switch but still have the problem. For example, the other night I was watching "Transformers", on the main surround (5.1) and about half way through the DVD it AMP just shuts down. Any help or thoughts would be appreciated.
  • 1 more comment
  • mblaksley Jan 20, 2008
    This is great information. I will follow up and see if I can get the code. Agree about the heating issues with the Z9.
    Thanks again for the help
  • sfang Apr 02, 2008
    I have Yamaha Receiver RX-Z9 dated from 12/2004, recently something wrong with the power, when I press the power button or from the remote control, it's on for less than a second and off itself for the first press, sometimes for more then 3 times, just like that, on and off(itself), but when I try a few more times, it stays on, OR sometimes it will stay ON after the first or second attempt.
  • dryslot Apr 08, 2008
    I'm having the same problem. I've never been a big Yamaha fan from the beginning, but I let my home theater guy talk me into it. Now I kind of regret it. It's beginning to feel like a $5,000 dollar brick. And, as others have reported, it runs nuclear hot. To counter that, I have a strong fan blowing across it in my already very well ventilated stereo closet. Despite the fact the fan solution works (no problem now touching the top or sides of the unit, it's barely even warm), the unit still kicks off after one to two hours. Nothing like a shut down in the middle of the 3rd quarter of your superbowl party.
    Perhaps there is some sub-circuit deep in the unit that is overheating, and not detectable from an external vantage point. Generally after a 15 minute wait, it will turn on again. Any attempts prior to that result in an immediate shutdown again.
    The manual says nothing about any kind of diagnostic sequence you can access to determine the cause. I've tried doing a reset with the power cord pulled out for 30 seconds. That didn't help this matter. The only thing left to try, before pursuing a professional repair shop, is setting the impedance from 8 ohms to 6 ohms. See page 30 of the manual for the simple instructions on how to do that.
    I made the change and have only checked to make sure I was still hearing sound, which I was. From here all I can do is wait until we watch our next movie, or some extended TV viewing and see if the unit is any more stable.
    I'm not too optimistic this will change anything, but worth a try. At least the manual did recommend to check this if one is experiencing 'power-up' problems.
I had a simular problem. Mine would intermittently cut off when powering on. which could also be same solution as as others since problem ended up being a bad connection on input power/relay board.. . If you are looking at top of receiver it will be at the very back toward the center. Take the small circuit board out being especially careful to mark where the connectors go so you can put back in proper place when reassembling. Mine had a very obvious bad solder connection on a wire. Yours may not be obvious so I would suggest resoldering all the wire connections . If yours only cuts off intermittently.. Hope this helps. Donald
Reply
Posted on Apr 29, 2011
  • 699 Answers
The Z9 does run hot and should not be enclosed in any cupboard. It needs about a foot (30CM ) of clearance all around it.
Posted on Feb 05, 2011
I also have the Z9, but since I'm living in Europe, it's de DSP-version. Not that it makes any difference, because mine faces the same issue. Heat does seams to be the issue, however, it's having the same problem when it has not been used for a couple of days. I admit, the occures where during summertime with 26 degrees Celsius in my living room.
After investigation of the shop, the advice was to put it further away from the television (both were directly next to each other).
Try it and see what happends.
Posted on Nov 30, 2008
  • R v L Nov 30, 2008
    By the way...it also seems that the turn on/off button on the Z9 itself ( so not on the remote) makes the problem worse.
I took my Z9 in for service as I had this same problem. It would run extremly hot. It took about a week but it was fixed for free under the 5 yr warranty. It now runs fine and is nowhere near as hot as before. I just can not figure out how to turn off the Zone 2 indicator.
Posted on Feb 01, 2008
  • neun9zig Dec 14, 2010
    Concerning Zone 2 indicator: Look at the manual, page 94. There is a description how to activate the "Zone"-mode for the big (black) remote. After you programmed the remote you can select "Zone2" using the the "Source Select" buttons and turn the Z9s internal Zone 2 amplifier on and off by pressing "System Power" / "Standby". Took me a while to find out how it exactly works... Positive side effect is that the unit doesn't get that hot anymore!
Your unit's internal breaker is tripping out. Hmmm...I think all of these high end Yamaha AVRs have a self diagnostic program. I have an earlier Yamaha model (1998) DSP-A1 and it does. You should be able to access the diagnostic readout by pushing the right buttons on the front panel. I have a service manual for my DSP-A1 and it shows how to do it for my unit. The diagnostic program stores in memory what fault caused the internal breaker to trip. I would suggest you get a copy of the service manual for the Z9. You can readily get one on the web from various suppliers for a small fee. My guess would be a high temperature trip as I have heard the z9s run very hot.
Posted on Jan 20, 2008
How do I connect a 24v damper motor with 6 colored wires red white yellow green blue black to NO COM NC terminals.
Choose two colors of the thermostat wire, and connect them to the NO and COM and connect them to the zone control board leads for the zone intended. Almost all zone valves spring return open when deenergized. So ensure the zone valve is open with the system is off. At the base of zone valve there is a set screw that needs to engage the damper valve shaft in the open position with the motor in the spring release position. Most zone valve are 90 degree moment from full open to full shut. If you have a Carrier zone valve, they go full open to full shut in 45 degrees of motion. Your open stop need to be set so the valve stops in the full stop position.
To help understand the operation of a zone system, say you have 2 zone system and zone 1 thermostat initiates a heat or cool demand. Zone 2 valves energizes and shuts and zone 1 stays open and allow air to heat/ cool zone 1. If zone 2 thermostat simultaniously initiates the same heat/cool demand, the zone 2 valve opens and both zone heat/cool. When either thermostat is satisfied the opposite zone valve closes and when both thermostat are satisfied both zone valves open.
Hope this helps you understand zone operation. The same works for higher multizone systems.
Jul 27, 2014 | Honeywell Motorized Small Rectangular Hvac...
Sprinkler will not change zones
You mean timer will not change zones? Is it from zone 1 to zone 2? Does the timer say it is watering zone 2 and no water, does it default and shut down on zone 2? Does zone 2 have run time? Can you be a little more specific?
Feb 19, 2014 | Fimco 1-1/2 in. 10 psi 6 Outlet Indexing...
My Nelson SmartZone Ez operates 4 zones. Zone no. 1, 3 and 4 operate normally but zone no. 2 doesn't. I can hear a click when the program tries to run the pump for this zone zone but after a second it...
Let me answer your second question first. The rain sensor should take a day or two to dry out, it is supposed to duplicate drying of the earth. It is, however, adjustable so it requires more rain to shut off and comes back on quicker.
Your timer may be operating properly but you may have a faulty control valve for Zone 2. In many systems, there are control valves for each zone.
Gary
Aug 10, 2011 | Hardware & Accessories
My Denon AVR2308 is frustrating me. I am running two zones (5.1 in main and zone 2 out of rear surround). I have made the audio setting to allow Zone 2 on/off, but i am stuck on how to turn sound off in...
Greetings,
Unfortunately the AVR2308 does not have the zone 2 video output connector needed to pass video to a second zone. The AVR2808 was the first receiver in that year lineup to offer a video output to a second zone. There are many different types of video outputs on that receiver, but they are all associated with the Main zone. This is why you loose the video when you shut down the Main zone. With respect to your Zone 2; the small remote that came with the receiver should have all the power and volume features you need to operate Zone 2 while keeping the Main zone turned off. The only audio that can be passed to Zone 2 though has to be in an analogue format (using the red and white RCA connections). This receiver does not pass digital audio onto Zone 2. Best of luck!
Aug 21, 2009 | Denon AVR-2308CI
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
solutiondoct
Sep 12, 2008 | Denon AVR-2807 Receiver
Problem: I am trying to Hook up my RX-Z9 and get sound out of MAIN.
Try pressing "Main A" or "Speakers A"-button on the remote-control (slide the shield at the bottom)
Nov 14, 2007 | Yamaha RX-Z9 Receiver
Zone 2 issues
Zone 2 only plays anolog inputs.
Aug 27, 2007 | Yamaha RX-Z9 Receiver
Yamaha RX-Z9 Receiver Logo
432 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
