If it is the timer you could manually turn it to go through the cycles. Most likely it is the pump. If the pump won't drain it won't spin hence it will stop right after the wash cycle. Pumps are fairly easy. Unplug the wasker. Remove as much of the water as you can. Pull out the unit and shut off your water supply hoses. Take off the back. The pump will be clamped to the largest hoses. Put towels on the floor once you take off the clamps all of the water will drain out. Replace the pump. Call Sears to get the new pump. Hope this helps-good luck.
