Mitsubishi WD-52525 52 in. Rear Projection HDTV Television
Problem for Mitsubishi WD-52525 52 in. Rear Projection HDTV Television
Steady blink green light, WILL NOT RESET!
By rvbrazeau on Oct 19, 2009
Hi, I have a Mitsubishi DLP TV model WD-52525. I had a power outage with the TV plugged into a top of the line surge protector. TV blinks a constant green light. It will not reset after several attempts over several days! This TV has low viewing hours (approx 500 tops) ( this TV in NOT our primary viewing TV)!! I paid top dollar for this TV and major problems, like this should not be happening with a unit with so few hours. Please help!!
Comments:
Oct 19, 2009
- Can this repair be accomplished by a mechanically inclined person, but with zero tv repair experience??
Oct 19, 2009
- Thank you very much for your help!!!
Best Solution
posted on Oct 19, 2009
Very Helpful)
Slinteriors
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 3764 votes
Thats a common problem with that model which is the V26 chassis. The V26 DM repair kit available at www.tvrepairworld.com should repair that issue. The kit contains the replacement capacitors and the CD with detailed instructions its 35.99 which includes shipping
Comments:
Oct 19, 2009
- Yes its basically very easy and the CD is very detailed with instructions. It requires very basic soldering to install the replacement capacitors.
Oct 19, 2009
- Glad that I could assist. You will find tvrepairworld.com a very good company as they will assist you step by step with your repair if you should need it just send them a email, the tech support is always free.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you for the extremely quick response and seemingly easy fix! I have ordered the repair kit already and will post my repair results when done! " - rvbrazeau
Popular Solutions for Mitsubishi WD-52525 52 in.
Questions and Unsolved Problems for Mitsubishi WD-52525 52 in.
Do you recommend Mitsubishi WD-52525 52 in. Rear Projection HDTV Television?
Answer
Answer
My kid slept on the remote and now the every channel and guide is in black and white but menu screen... (More)
Answer
I have a mitsubishi medallion HD 1080 that will not turn on. My toddler would turn it off and on... (More)
Answer
diaginal lines in picture. When you use PIP, the smaller picture appears to be ok. When you switch... (More)
Answer
have a 60 inch mitshubitshi dlp and no red color, with mainly green and blue only. Is it expensive... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
