Washer will not Spin during SPIN CYCLES
My washer will fill with water, it will spin both ways during the wash cycle but when it goes to the spin cycle you can hear the machine draining the water but it does not spin. It will then go onto the rinse cycle where it will again spin both ways and then you can hear it start to drain and go into the final spin cycle but the machine does not spin for it. Help PLEASE!
hello, our washer is having a similar problem where it will do the final spin, but no draining. its filled with water after every final wash. its a front load kenmore model 41741142000
  • Anonymous Dec 08, 2008
    I have the same problem. Unfortunately 8 months ago it quit spinning and I called the SEARS REPAIR SERVICE from the booklet that came with the washer and they fixed it to the tune of $ 370 !!! AND...8 months later, same thing again and I called them and guess what THERE IS ONLY A 3 MONTH WARRENTY ON REPLACEMENT PARTS AND LABOR FROM SEARS !!!! buyer beware . Take it from me...just buy a new washer!
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
check the lid switch on the washer its below where the tab on the washer lid that goes down in the body of the washer there two screws at the base of the control panel back these out and raise the panel you will see a connector coming from the washer disconnect it and put a jumper wire where it goes to the control panel turn it to spin pull out the knob if it spins replace the switch if it doesn't reply to me and we will go from there
Jan 30, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
639 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
