I have an Onkyo SR702 reciever that has lost it's audio. I checked all of the connections, settings, etc. and tried to run the auto speaker config with no luck, there is no audio output. I did 'clear' it by pressing Video 1 and the On-Off switch but that didn't help either. Any thoughts?
I haven't opened it up to look for obvious 'fried components' and the like. It doesn't have the burnt component smell to it at all. Appreciate any help.
I would like to repair a RD-820 cassette player that the mechanism fails. I think it may need all...
(More)
I would like to repair a RD-820 cassette player that the mechanism fails. I think it may need all the drive belts replaced. Can these be obtained? or Can the cassette mechanism be replaced as a unit? John
after approx 15 mins use, system only responds to some remote commands. typically, switches to...
(More)
after approx 15 mins use, system only responds to some remote commands. typically, switches to "multi-room" mode even though "multi" function has been disabled. seems to be heat related, but i've tried numerous configs using multiple fans pumping air into/out/across the unit. seems to help but remote commands eventually fail. no UL, ETL, etc. certified equipment should be this sensitive to heat.
Surround sound on str-de698 does not work (blue light does not light up). SW (set to "No")...
(More)
Surround sound on str-de698 does not work (blue light does not light up). SW (set to "No") & SB speakers not connected. Set up for 5-0
