Question about Linksys EtherFast EZXS88W (DSLSEZXS88W) 8x10/100 Mbps Networking Switch
Changed from DSL to cable
I just changed my internet connectivity from Qwest's DSL service to cable provided by Cox Communication. I thought I could merely switch the RJ45 connector that is plugged into my DSL modem (and my Linksys EZXS88W) into the Cox cable modem and begin to use the faster cable internet service. Not only do I not get internet connectivity across my network, in fact I only get one machine connected to the internet, but the access to the other computers on the network is limited, e.g. I cannot share files across the the network. What do I need to do?
Usually DSL connections require ppoe while cable uses dchp You need to log into your router and change the settings
Posted on Dec 31, 2007
I am trying to connect a D-Link DIR-628 router to a Qwest Actiontec GT-701-WG DSL modem. My computer OS is windows XP-service pack 3. The modem works fine when connected directly to the computer and...
Plug your internet into the router then, the router to the computer. Go to your network settings and run the network setup. This will change the settings in windows to except the router into the network. You may have to restart the computer. This should give you internet access to your computer through your router.
Jan 27, 2011 | D-Link Computers & Internet
Router communication with cable modem
If you change service providers, connection type and hardware, then all your previous connection settings will not work, and they'll have to all be reconfigured.
Have you been given a new modem/router (combo unit)?
Did you previously have a separate modem and a separate router?
Do you connect your xbox via WiFi?
Go back to basics now. If your computers connect fine, then connect the xbox using an ethernet cable and see if it works. Then try wireless.
Feb 27, 2010 | Belkin (F5D7230-4) Router (587009)
I need instructions for a Linksys Wireless G router to work
Call your internet provider they will walk you thru the process.
Jun 18, 2009 | Linksys Wireless-G WRT54GS Router...
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Hooking up rounter to cox cable
hello!
-- what is the operating system of your computer?
-- is the router working fine before or is it a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 27, 2008 | Linksys Wireless-G WRT54G Router
Installing a internet modem
you open case
have comp turned completly off
install ethernet card into proper slot screw down
turn on comp goto control panel network setup wizard follow instructions from there
remember first your modem has to be recognized by your service provider first before you can get that connection and they give you the service to connect
say like cox qwest or other service provider
May 09, 2008 | Dell Inspiron 5100 Notebook
We recently got high speed internet from Qwest. It will not work. It keeps saying that the can't "ping" it. All light are green; power DSL, and the Ethernet. The internet is not. I have...
The DSL router/modem will receive an address from your ISP (Qwest) and will assign an address to the connected PC.
There should be a cable that goes from your DSL modem to your PC. It'll either be a USB cable (flat rectangular plug on the PC end), or a RJ45 (looks like a wider telephone plug).
If there is neither connection between the DSL modem and your PC, then the PC can't "talk" to the DSL modem, so it's not getting an address from the DSL modem.
Apr 06, 2008 | Computers & Internet
Linksys EtherFast EZXS88W (DSLSEZXS88W) 8x10/100 Mbps Networking Switch Logo
249 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
