Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore i notice my freezer as thought out all water in the ice bucket fan is running whats the problem
    Scholar:
  • 90 Answers
Could be a bad defrost timer. Can you tell if the compressor is running? That would be the first thing to find out. If you are not familiar with checking, better get someone that knows. Can get shocked if you are not careful.
Posted on Jan 28, 2008
No water entering Ice Maker. Noticed the problem when water was dripping out of the fitting on the back of fridge that goes to icemaker. Also the icemaker is not making ice. Tightened screws but...
Ok i would disconnect the water hose to the frig, turn off the water. first
then put the end of the hose, in a bucket..see if you get a good flow of water, if you do..2nd your going to have to buy a new fitting..for the copper or plastic hose. then lets go from their
Dec 18, 2010 | Kenmore 77309 Bottom Freezer French Door...
Hi, I have a Whirlpool refridge. The ice maker is making ice, yet the ice is not dropping into the ice bucket. If you put ice into the ice bucket it will correctly drop through the door. The ice seems...
Hi and welcome to FixYa. I am Kelly
Often ice maker issues are a symptom of an automatic defrosting problem OR a leaking (dripping / bypassing) ice maker water valve.
First off you should try and prove that there are no un-necessary water leakages by doing the following:
1. Turn the icemaker OFF
2. Remove the plastic line where it connects to the thru the cabinet water tube by pinching the clamp and pulling down on the plastic tube.
3. Place end of the plastic tube into a bucket for about 12 hours. At the end of 12 hours check the bucket for ANY water. If there is a noticable amount of water (more than 1 oz) the water valve is leaking water by the valve diaphram seat. The only remedy for this is to change the units water valve assy.
As far as a possible automatic defrosting problem..... soft ice cream is a symptom along with that of low ice production.
The evaporator coils get a substantial amount of ice build up on them and then the airflow in the freezer compartment is restricted resulting in a change in the freezer comprtment temp. If you do have an automatic defrosting problem you will soon notice noise from the evaporator fan as the ice build up encroaches into the fan blade path. Additionally the fresh food compartment will warm up.
The ice maker will not cycle until it reaches 16 to 15 deg F. The ice maker harvest cycle is started when the ice maker thermostat closes and advances the ice maker module.
Do the water in the bucket test and then look for signs of ice build up on the evaporator coils.
If neither of the above manifest / present then download this manual and follow the troubleshooting procedures:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Thanks for choosing FixYa.
Kelly
Sep 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Coldspot 106-52609100 side by side is not working, freezer is only cold at the bottom and the refrigerator is not as cold as it should be. I opened the freezer to get something out and noticed the...
HI,
Can not type all the answers to you cause it is very log for me to do that.
You can use this link to solve what ever problem you would want to check consigning you fridge. It will surely help you out.
repairclinic.com/Refrigerator-Troubleshooting.
You can check very well and the solution will be solved.
Take care.
Apr 20, 2010 | Refrigerators
I am not sure this is the right refrig. I have a model 253.78259800 top freezer with a model JD-21 ice maker. The ice bucket keeps filling up with a solid piece of ice. It makes and drops cubes, then water...
there s a adjustment but it only controls /like 1 to 2 oz of water . its prbably the ice mker unit or the water valve . .. ice mker tell water how long to let water in and if valve is bak it might not shop off causing water fill . change water valve first . then ice maker if needed .. icemker might have a bad tray and some cubes do not drop / if so next fill will over fill causing problem . mm
Dec 07, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
I am looking for a schematic for the kenmore 51 lbs ice maker
There is supposed to be a cap or plug , at the bottom of the water bucket , to hold water for the recirculating pump . There is no cap at the bottom of the ice bin .
Sep 09, 2009 | Kenmore 51lb. Clear Ice Maker
Kenmore fridge ice maker
This is the ice maker that is the problem. The ice maker is controlled by an electric solenoid valve in the rear of the frig. Over time they have a tendency to become corroded by the chemicals in the water and will cause undesired operation of the components. Hope this helps. Good luck.
Jun 11, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Kenmore refrigerator freezer not freezing
Yes that is a proplem...when ever that compressor is running that fan motor should be running too.. also you evapurator fan motor should be running also
Aug 20, 2007 | Magic Chef CTB1722 Top Freezer...
Ice maker not making ice
Check the cam wheel beneath the front cover of the icemaker it is probably not turning.
May 31, 2007 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
