Question about Zenith C27A24T 27" TV
Zenith SR3238RK The channel is locked on one channel and we can't change it. How do we get it to channel 3?
  • adisson May 11, 2010
    Which button are you referring to when you say the "adjust" button?????
You have to access to the service mode , press at the same time channel up & down and the adjust button up , you will see a menu, find with the remote the funtion channel lock the values are 0 or 1 select 0, now Should be in 1 and that`s because you can not change channels , good luck , please dò not change any other value or better, writte down all the values before you change any.
Posted on Jan 13, 2008
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
I have a Zenith SM2067BT TV set. When I turn on the TV, it is evidently turned to the wrong channel. It comes on channel 2 instead of three. When I try to change the channel to 3,it reads aux or aux seq. I...
you must be on a box, put your tv on channel 2or3 then with the control for the bx channel up-down if not then just do channel up-down manualy
Feb 14, 2010 | Zenith B25A02Z TV
How to change vcr input from channel 4 to channel 3
On the Zenith, turn the power off. Hold down the Channel up or down button on the machine itself (not the remote) for 5 seconds, it will say RF03 hold down until it says RF04.
Apr 27, 2009 | Zenith XBV243 DVD Player/VCR
Zenith A25B33W changes channel sporadically
sounds like the little button switches are leakey they are mounted to the board and are very small may need to replace them. They are right behind where you push the power on channl up down and so on buttons on the set.
Mar 09, 2009 | Zenith A25B33W 25" TV
Unlockin all the channels
In order to get all the channels u have to have the original remote or a universal remote that has a menu button, an enter button, and directional pad (the directional pad cannot control the volume and channels it must be for navigating). push and hold the menu button, the menu will appear then disappear, once it disappears release the button and enter 9876 then press enter. a different menu will appear and it will b three black lines, one at the top of the screen, one in the middle and one at bottom. the middle line has 3 sections the first part is the item number the second part is the description and the last part is the on/off switch using either a 0 or 1. push down on the directional pad until u get to the 00 factory settings 0 and change the 0 to a 1 with the right button on the directional pad. then scroll up to 20 channel lock 0 (i think its 20, it may be like 22 but it is in the twenties for sure) and change the 0 to a 1. then go back down to the 00 factory settings and change the 1 back to 0 then turn the tv off. when u turn the tv back on it will either automatically ask u to auto tune or u will have to go to auto program to program the channels. there are like 80 different menu items, be sure not to mess with any other ones unless u know what ur doing, u could cause ur tv not to function properly or even be able to turn on.
this problem frustrated me greatly and im very happy to help whoever i can with the solution
Feb 07, 2009 | Zenith C27A24T 27" TV
Change to channel 3 rather than 2 on Zenith 27" withot a remote
You can use the menu button on the front to autoprogram the unit. Make sure the direct tv is on so the tuner will pick it up. After that, you can program the direct tv remote to operate the tv. The reason the channels won't change is there are none in the memory
Dec 19, 2008 | Zenith C27A24T 27" TV
Zenith zn620 universal remote
This may be of help for Zenith codes:
http://www.thompsontv.com/zcodes.html
Jul 20, 2008 | Zenith ZN620 Remote Control
Zeith 27 inches 2001
You will need a Zenith remote with a menu button
There should be a "hidden" menu. Before you access it, I want to warn you, do NOT change any values of anything you don't understand what it is or does. You can PERMANENTLY DAMAGE YOUR TV. Also, write down the original values of anything you change before changing it!!!!!
If you still want to proceed(at your own risk), here ya go.
1. Press and hold the menu button until
the menu comes up on screen and then
times out (5 - 10 seconds)
2. Immediately press 9, 8, 7, 6, Enter.
3. The set should now be in the service menu
mode. To access most of the features
selection 00 needs to be toggled from 0 to 1
4. After your adjustments 00 needs to be
toggled from 1 to 0
5.Feature 16 unlocks the auto-program (change to 0)
May 28, 2008 | Zenith C27A24T 27" TV
Zenith zn110
1. hold in "code search" till light stays on
2. press channel up until tv changes channel
3. press enter as soon as channel changes
note: if you pass  the  right code just use channel down to get back to it
Oct 21, 2007 | Zenith ZN110 Remote Control
Zenith Model SR3238RK horizontal lines
There must be a capacitor which would be brust or leaked.So check it in th horizental section.And power supply section.Find that one and replace it. Good luck
Aug 12, 2007 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV Logo
161 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
