Question about Panasonic CT-36HL43 36" TV
My tv dose not turn on
My tv not turn on
I have a Panasonic CT-36HL42 television, the tv will not get power try to turn in on and nothing. any suggestions are appreciated
I have a ct-36hl43 it was ac fuse gma 6.3 amp its on the panasonic web site under parts cost a dollar randy vincent
Posted on Feb 25, 2008
Ct-36hx42 fuse replacement
Take the back right next to the ac cord. Should be a 5 or 6 amp,
Oct 29, 2011 | Panasonic CT-36HL42 36" TV
Will power up only after the power cord unplugged and plugged back in to the outlet. Then shuts back off again. CT-36HL42CF.
High voltage too high going into xray protection. Check the collector of the horizontal output transistor for 130v dc.
Oct 10, 2011 | Panasonic CT-36HL42 36" TV
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
My picture dose not work but my sound dose how do i fix this problem
go for the HORIZONTAL OUTPUT TRANS or THE VERTICAL IC , , check those 2 sections , good luck AJ
May 15, 2009 | Panasonic CT-32E13 32" TV
Front cover removal on Panasonic CT-36HL42C
You have to remove the entire rear case to access the video input(s) panel. There are quite a few screws. Be careful when removing the case because there is an internal wire connected from the inside back of enclosure to the main power board.
Jan 07, 2009 | Panasonic CT-36HL42 36" TV
Hello, My Panasonic ct-36HL44 won't turn on. It's complestely dead. Yesterday and for the last 4 years---its been perfect, completely reliable. What happened? Is there a fuse inside the chassis and can I...
I had the exact same problem with this model a few months ago. Repairman came out to my house and told me that Panasonic is well aware of the problem but never issued a recall on it. He then charged me $150 to take off the back of the tv and replace a blown fuse with another fuse with a slightly higher voltage rating. Took him all of 5 minutes. He took off back of tv and the fuse is located, if you are standing at the back of the tv, on the bottom in the left hand corner. You can't miss it. I wish I could tell you which fuse he put in but I didnt see it. Sorry. Try it for yourself and you might be able to save $149.50, b/c I doubt that fuse cost much more then 50 cents. Good luck.
Mario in NY.
Dec 09, 2008 | Panasonic CT-36HL42 36" TV
No power
There is a 6 AMP 125 Volt fuse on the main power board. My CT-36HL42 would not power on so I replaced the fuse and it works.
May 18, 2008 | Panasonic CT-36HL42 36" TV
Panasonic CT-36HL43 36" TV Logo
347 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
