Question about IBM Infoprint 1532 Laser Printer
Infoprint 1532 ibm micr printer
I got it from canada and try to use it in Australia and i blow the fuse, what i want to know is can i just change the fuse?
This unit is the low voltage type 110v compared to Australia voltage which is 230v therefore you will have to buy a new printer
Posted on Feb 22, 2008
Why is my infoprint 1532 saying load mp feeder?
Driver is telling the printer to print single sheet. Load a single sheet or fix your driver/software settings.
Jul 09, 2014 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 giving error code 922.14 -service fuser error
There is a heater control problem in the fuser.
The fuser is the assembly of heated rollers in the rear of the device.
The most likely cause is either a blown heater element, or perhaps a faulty temperature sensor.
Usually we fit an exchange fuser assemblt to fix this.
Feb 04, 2010 | IBM Infoprint 1532 Laser Printer
1332 infoprint printer not supporting 1332 toner cartridge
If the toner in the machine is NOT MIRC it will not work in a MIRC printer. Get the correct toner cartridge or get a NON MICR printer to put your toner in. MICR uses a special toner (magnetic) for printing checks and the printer is usually modified at the factory (troy or others) to make it print using MICR toner. No way around it.
Aug 14, 2009 | IBM Infoprint 1332 Laser Printer
Refilled toner and now printer reads - 30 invalid refill
The toner used must be for a different printer. That error message is displayed when the chip on the toner is not the correct one for that printer. It may be a defective cartridge, or the incorrect model. Try to go back to the place you bought it and return or exchange for the correct one.
Jun 16, 2009 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Jun 03, 2009 | IBM Infoprint 1532 Laser Printer
Tray 1 Low
How many input trays does this printer have?
Trays can be renumbered to allow for larger capacity input trays.
Please print out the menu setting pages and verify the correct paper tray numbers.
Don
May 15, 2009 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 Tray Selection
For tray linking to work, both Paper Size AND Paper type must be configured the same for both trays. You probably have the paper sizes the same but types could be different. The is no setting to make tray linking work.. it will do it automatically if the above settings are correct.
Feb 24, 2009 | IBM Infoprint 1532 Laser Printer
Infoprint 1532 Faded txt on left half of page and normal on right
The problem is the transfer roller. If you remove the toner cartridge and look at the roller that is under it. It should be seated down. The gears should be on the left side. Try to remove it and replace it the correct way.
Jan 13, 2009 | IBM Infoprint 1352 Laser Printer
IBM Infoprint 1532 printer not working
count the beeps, the number of beeps detemines the error.
Nov 14, 2008 | IBM Infoprint 1532 Laser Printer
Lexmark 1532
If the Operator Panel is locked. (Menu's disabled) you need to enter Config Mode to enable the operator panel. Press and Hold the > right arrow and down arrow buttons while powering on the printer. Once in configuration mode scroll to Panel Menu where you can enable it. Exit Config Mode or just power the printer off and back on.
Mar 28, 2008 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 Laser Printer Logo
113 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
