Question about D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842)
Dlink Router not assigning IP to NAS
I am running a D-Link DI-624 router in my home network.  I have it hooked to a Motorola cable modem via the WAN cable, to my Mac G5 via an ethernet cable plugged into LAN port 1, and to a Infrant readyNAS via an ethernet cable plugged into LAN port 2.  I am also wirelessly connecting a PC laptop my network.  The Mac and the notebook connections work great.  The NAS asks the router for an IP address, but the router does not provide one.  I have the DHCP server enable on the router.  I have been unable to connect to the NAS over my network.
  • Paul Sawatsky
    Paul Sawatsky Dec 31, 2007
    Updating the firmware solved the problem.  Thanks.
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Posted on Dec 29, 2007
My dlink is set up and it shows on my wireless network but when i connect there is no internet comng through it just goes to a can not display this screen at this time page
Check the WAN light on the router -- if it is not lit, then your router is not connected correctly to your cable-modem or DSL-modem.
Start Internet Explorer, and access the web-server "built-in" to the router. Access the "settings" page, and check the "WAN" settings, to ensure that the router has received an IP-address from your Internet Service Provider.
Sep 15, 2010 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI-524 is not communicating with modem
Checklist:
* Is DHCP configured correctly?
* Connect your server and laptop to a switch (not directly with the cable)
* Can they ping each other?
* Check that the firewall is configured (or switched off if you have another FW in place)
* Default gateway should be your router, not the computers (until you have configured RRAS for example)
Here you can find more information about how to configure various roles in 2008: http://technet.microsoft.com/en-us/windowsserver/2008/default.aspx
Sep 07, 2009 | D-Link AirPlus DI-524 Wireless Router
Having difficulty installing DL 624 with vonage
On my Vonage setup, I had to hook the Vonage unit's blue port to the Cable modem, then connect the router to the Vonage's yellow port.
For some reason, the router would not assign an IP to the router the other way.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 10, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I need drivers for an older wireless router
Routers dont have drivers, but for firmware updates go to this site
http://www.support.dlink.com/downloads/ for further infomation.
To configure your router.
>Make sure you have Internet connection on your modem
>Connect the modem to the router using an Ethernet cable under WAN port of the router.
>Another Ethernet cable should be place on any LAN port on the router going to your computer.
>Access the configuration page of the router (192.168.0.1) on the address bar.
>If you have the login page, Type admin/Admin on the username and leave the Password Blank.
>Once inside click on Home and choose WAN on the left side.
>Choose Dynamic IP address
>Click on Clone Your PC Mac Address
>Click on Apply > click Continue..
>Click on Status
>Under WAN look for the IP Address
>If you have values on it beside from 0 it means you have Internet connection now. otherwire call your Dlink for manual assistance on configuration your router for Internet connection.
Feb 01, 2009 | D-Link DI-514 / DWL-520 Kit...
No wan light
If no wan light bypass the dlink router and check if ethernet cable connected to wan port is working. Once you are able to go online through modem connect cable to WAN if light does not go on log into oruter and clone mac address and save settings.If doesnt work powercycle router and turn modem on first then router next if doesnt work upload latest firmware.
Sep 05, 2008 | D-Link AirPlus DI-524 Wireless Router
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
Dlink solutions
you just cleck dlink, then properties, then cleck advance check the computer internet
Jun 18, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Feb 01, 2008 | Cisco 675 Router
Can not connect to router via a wireless connection.
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Jan 23, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
330 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
